324 user(s) are online (285 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Seats
Both could be power, neither could be.
However, if they are, they should move fore/aft and up down with little more than an electric motor whine....
Schrade Re: So much for going drag racing tomorrow
eastern NC / e-i-e-i-o
1909 Posts
Sometimes belts slip (NOT Serp Belts) when cold startup, but never hot re-start.
Serp Belts don't know???
Posted on: 2016/7/28 17:34
LT5, Marc Haibeck ECM module, AUTOMATIC!!!
BrianCunningham Re: So much for going drag racing tomorrow
OK I'm used to the stretching over time.
Took it for a spin.
Seems to be running good.
Seems to be running a little hot
Of course it's 90 degrees outside.
Posted on: 2016/7/28 20:04
Not a good year for the Vette
1st I needed to get my engine oil leak under control
I rerouted the PVC, that helped out quite a bit
Then the supercharger pulley destroys itself from the engine torquing it into the frame rail
Now, driving around town to see if I got it all straightened out I hit pothole in front of a railroad track and the mount for my coilover shock got TORN OFF the upright!
Posted on: 2016/8/24 23:36
1909 Posts
Pics? What's involved in the fix?
Posted on: 2016/8/25 16:27
I'm going to take it apart this weekend
My be able to get it welded
If not, I'll have to locate another stock upright & a coilover over mount which needs to be modified to clear my rod end links. Then have it all welded up again.
Posted on: 2016/8/25 23:07
Looks like I'll be needing a new upright & mount
I should probably rebuild the shock as well
BTW these mounts are NOT as they are sold.
I needed to reposition hole to get the clearance I needed.
In the process the bolt holding the shock on no longer aligns with the former shock bolt location.
The induced torque is what twisted the end of the casting off.
jpg  IMG_20160827_153016_644.jpg (828.36 KB)
921_57c1f0c3cf2a4.jpg 3264X1840 px
Posted on: 2016/8/27 19:58
rklessdriver Re: So much for going drag racing tomorrow
Woodbridge, VA
1318 Posts
Which side do you need?
I have a right side one taking up room in my garage that I will pay it forward to you, if you pay shipping cost.
Will
Posted on: 2016/8/28 1:07
1984 Corvette. 434 SBC with a Powerglide.
Best pass - 8.48@160MPH 1.23 60ft on MT 275/60R15 Radials.
1972 Corvette. LS5 454 BBC with M20 4 speed.
Best Pass - Doing good to just pass a gas station.
Passenger side
I appreciate the offer
Posted on: 2016/8/28 17:37
Managed to break my breaker bar trying to get the stub axle nut off.
I'll get another one and perhaps another impact gun
My battery powered one won't cut it.
Posted on: 2016/8/28 22:49
1909 Posts
Broken Breaker Bar? Too much Gym time there Arnold...
Posted on: 2016/8/30 20:20
Went out and got a 3/4 drive breaker bar and appropriate socket
I'm STANDING ON it and it will won't move
Hit the end of the breaker bar with a sledge, still nothing.
Posted on: 2016/9/2 22:23
1909 Posts
Can you get a propane torch on the nut, then see if it will take penetrating lube while nut is heat-swelled?
Posted on: 2016/9/3 16:35
FINALLY!
My neighbor had length of steel pipe that I trusted as a cheater bar. That got the nut off
Got the upright off the car.
The damage looks weldable.
The shock on the other hand.
The rod is no longer centered in the body.
It probably got torqued.
I'll have to tear it down and see what's going on.
jpg  IMG_20160904_154025_824.jpg (756.85 KB)
921_57cc88998e4c1.jpg 1840X3264 px
Posted on: 2016/9/4 20:48
Dropped the rear shocks and upright off
Here's hoping for good news
Seems obvious that the shock bottomed out before hitting the bump stops
I'm pricing some shorter rods
Posted on: 2016/9/18 21:59
383tpimachine Re: So much for going drag racing tomorrow
Corpus Christi
976 Posts
What length are they currently compressed and fully extended?
Posted on: 2016/9/20 19:48
1985 Atomic Orange 400YSIT56-Racecar build
1970 El Camino-Awaiting LSX
Had it written down
of course now I can't find it
Posted on: 2016/9/23 0:01
Update
The shocks are off getting rebuilt with shorter rods
The upright is JUNK, cannot be repaired
Coming up with a different mount scheme
Of course that means buying 2 so they match.
Posted on: 2016/10/23 18:28
bogus Re: So much for going drag racing tomorrow
Curious question... what if you drill out the hole even bigger than required and insert a steel sleeve into the hole to tighten it all back up again?
It would require some kind of protectant on the sleeve to slow/stop galvanization...
Posted on: 2016/10/28 0:42
On a new one or the damaged one?
The damaged one is to far gone.
On a new one, not really necessary, just unscrew the mount.
The shocks are back from Penske.
Seems I was wrong, it did NOT bottom out.
The shock managed to take a side load.
Looking back I remember clipping an apex.
That may have started it to fail.
The pothole just pushed it over the edge.
The shock got twisted as the mount came apart.
Posted on: 2016/10/31 23:02
that's a shit load of lateral energy!! that could happen to anyone, really. Coil overs or not.
Posted on: 2016/11/1 18:16
indeed
new set of mounts is $250
then I'd have the modify them
https://www.vansteel.com/index.cfm?fus ... jpg&title=CO-C4-RR-LWRMNT
Let me see what I can get a pair of uprights for.
Posted on: 2016/11/2 23:14
