movnviolation | Elevation sensor? | ||
What on my 89 controls the running conditions at different elevations. My car is modded with Mini, heads, cam and headers etc.
My tuner is in the Los Angeles area and set the air/fuel ratio right on close to sea lavel. The car smokes (hauls ass) down there. I live at 3600 feet and the car runs good up here, but when it idles, it loads up and idles rough. Just changed the IAC, and the old one was covered with carbon. Looked like the inside of a chimmney. no codes! Any thoughts? Thanks |
Posted on: 2009/10/27 2:43
Mods AFR 180 comp. heads w/ heavy springs. TPIS ZZ409 cam w/ 1.6 roller rockers, TPIS long tube headers, Miniram, 52mm throttle body, 24 lb Bosch injectors, Level V TPIS chip |
Aboatguy | Re: Elevation sensor? | ||
Posted on: 2009/10/27 2:45
movnviolation | Re: Elevation sensor? | ||
Thanks
Would a failed MAP sensor throw a code?? |
Posted on: 2009/10/27 2:57
bogus | Re: Elevation sensor? | ||
yes.
Posted on: 2009/10/27 3:00
Thanks
No codes! |
Posted on: 2009/10/27 3:19
No MAP sensor on the 89. 84 and 90-95 used MAP. 85-89 used MAF.
Posted on: 2009/10/27 8:07
mseven | Re: Elevation sensor? | ||
It needs more tuning, the AFR maybe good at wot but normal c.l. operation sounds pig rich.
Posted on: 2009/10/27 9:20
