DaleD | PCMforless gave up. | ||
I was doing what Alvin asked.
Had a lifetime on the MAF, so I replaced it. Checked fuel pressure. Replaced and adjusted the TPS. My car still ran crappy with the chip, and good without. Alvin authorized a return. Got the check today. Disappointed, but glad PCMforless stood by their stuff. |
Posted on: 2010/1/14 23:53
Whenever someone says "I'm not book smart, but I'm street smart", all I hear is "I'm not real smart, but I'm imaginary smart". |
bogus | Re: PCMforless gave up. | ||
gee... we still need to talk...
Posted on: 2010/1/15 0:52
tpi421vett | Re: PCMforless gave up. | ||
I would talk to Mick (Mseven) and see what he can do for you.
Posted on: 2010/1/15 1:47
AFR Dealer, can sell at prices too low to advertise. 801-953-6391 08 C6 LS3,3LT,Z51,A6,NPP 91 vette,450ci, AFR 220, miniram,FAST, Crane 252/260 solid roller, 200 shot nos, ZF6, 4 link, 9", DA corrected to 1300 ft 9.65@145.xx 450ci now with AFR 235... |
DaleD | Re: PCMforless gave up. | ||
I bought the chip for 2 reasons: #1 - Turn on the fan at 215* instead of 230* #2 - VATS defeat. My car is stock, so I didn't expect a performance gain. I didn't expect a drivability issue! I think Mick said he doesn't know how to do the VATS defeat. |
Posted on: 2010/1/15 3:10
1987? There is a way to bypass VATS...
Posted on: 2010/1/15 4:29
mseven | Re: PCMforless gave up. | ||
DaleD wrote: No I didn't say that....the things I don't do are: work on "flash" type ecms (some have a soldered in socket which then makes it doable for me), and the other is re-use stock type chips. This requires those who have me do their chip/tune purchase a gp1/2 from moates and chips. |
Posted on: 2010/1/15 13:38
Ok, my mistake. I was going from memory, which is problematic at my age. |
Posted on: 2010/1/15 14:34
89Vette | Re: PCMforless gave up. | ||
Did they suggest reburning another chip? With such a simple software change, it seems more likely to be a chip issue. IOW, the chip itself was bad.
Posted on: 2010/1/16 5:17
383 stroker -- Semi-Siamesed SLP long-runner intake, AFR 195's, 4-2-1 headers, and a SR cam. ZF6 short-throw shifter. Custom body/interior. |
Weavsvet | Re: PCMforless gave up. | ||
I changed tuners myself and decided to give this guy a shot. I can't speak for his work yet but maybe he can help you. I think his main gig is LT1's but I'd at least shoot him an email.
http://www.lt1pcmtuning.com/ |
Posted on: 2010/1/16 12:34
anesthes | Re: PCMforless gave up. | ||
You can bypass vats for the ECM by setting the flag in the bin. If the starter enable solenoid dies, you still need to replace it or splice the wires. -- Joe |
Posted on: 2010/1/16 13:00
Posted on: 2010/1/16 16:59
dan0617 | Re: PCMforless gave up. | ||
Yes, go to that site. Click on the starter enable relay link. The starter enable relay is what needs bypassed. I have mine bypassed and have the vats turned off in the chip. Mine is an '89.
What year is your car? What is the 4 letter code on the factory computer chip? (mine is ARAP, yours likely is too since it is a MAF car) |
Posted on: 2010/1/17 14:24
