147 user(s) are online (79 user(s) are browsing Forums)
Early SBC
4.3L 265ci - 1955 thru 1956
4.6L 283ci - 1957 thru 1962
4.9L 302ci - ...
traiconghoa HELP TO REPLACE A DISTRIBUTOR FOR A 96 VETTE
27 Posts
I want to replace a distributor for my 96 vette. Is there any special tools that I need to get to do the job, and can distributor cause misfire to the engine? Thank you very much!
Posted on: 2007/11/5 21:27
red_johnny RE:HELP TO REPLACE A DISTRIBUTOR FOR A 96 VETTE
If your talking just the cap which I assume you are you dont need anything special. Could it cuase that yes but I would take the cap off and inspect the rotor and see if the contacts are ok or not. Just compare the old to the new.
Posted on: 2007/11/5 22:53
bogus RE:HELP TO REPLACE A DISTRIBUTOR FOR A 96 VETTE
this distributor is called an optispark.
yes, it can cause a miss.
replacment is a real thrill... it requires removing the water pump and crank pully.
I will elaborate later!
Posted on: 2007/11/5 23:32
Duh, thats right...a 96 sorry I was not thinking
Posted on: 2007/11/6 1:25
ok... I am at my computer. Earlier, I was on my PDA... typing is slow one thumb at a time.
The Optispark can cause a miss. How old is the opti? Mileage and overall condition of the car?
Before I get to deep into this, I need those questions asked.
Posted on: 2007/11/6 2:03
Eagle223usa RE:HELP TO REPLACE A DISTRIBUTOR FOR A 96 VETTE
Guru with Eyes of Steel
God's country, Pa
197 Posts
Bogus, Did you catch that in his original post? "I want to" After doing mine I never want to do it again! I will cause I have to, not because I would want to!
Posted on: 2007/11/6 22:30
God's country, Pa
197 Posts
http://www.corvettefever.com/howto/16758/index.html, Check this out. It's how I did mine, no sense reinventing the wheel by typing it all out. Just do your plugs, wires and everything else you can think of at the same time.
And read it alll before you start! :thumbright:
Posted on: 2007/11/6 22:46
SJW RE:HELP TO REPLACE A DISTRIBUTOR FOR A 96 VETTE
Central Maryland
51 Posts
Consider the MSD as an alternative to an OEM replacement unit. The second-gen Opti in your car is much better (and less expensive) than the lousy first-gen units were, but if you want to hedge your bets, go with the MSD. If DynaSpark is still in business (which seems to be in doubt these days), consider their product as well. I installed a Dyna in my '94 back in 2004, and have been very pleased with it.
If you have a good set of general mechanic's tools, and decent mechanical skills, you can tackle the Opti swap yourself. No special tools are required. Here are a few tech tips I wrote up some time ago about doing an Opti swap:
Get a Factory Service Manual, and follow the procedure it lays out.
A few tips (I'm going from memory here, so I'll probably forget a few things):
Drain the cooling system.
Disconnect the MAF sensor and IAT sensor and remove the air intake duct with the MAF and IAT as an assembly.
Disconnect the ECT sensor and remove it from the water pump.
Remove the serpentine belt and tensioner.
You may find that you’ll need to unbolt the coil/ICM bracket from the front of the right cylinder head. I can’t recall for sure whether or not I did.
Unbolt (but don't remove) the power steering pump. This will help you to sneak the new plug wires in/out behind the pump, but may also be somewhat helpful when working on the water pump/Opti.
If you want more room to work, you can remove the radiator, but it isn't strictly necessary, and it involves considerably more work to remove it (I left mine in place).
The FSM will tell you that you need a special Kent-Moore puller to remove the crank pulley/damper. You don't. Here's how to get it off:
1. Raise the front of the vehicle enough that you can get under the car (it's also helpful to have it at a more comfortable height while you're working from above).
2. Remove the three bolts that secure the pulley/damper to the hub.
3. Mark the damper and hub so that you can easily see how to realign them to each other later.
4. Slide under the car with a long pry bar or hardwood dowel (I use a jumbo Snap-On screwdriver that's around two feet long) and a mallet.
5. Place the tip of the pry bar against the rear face of the damper, as close to the hub as possible (Ideally rest the tip alongside of the hub).
6 Give the pry bar a few whacks with the mallet, and with any luck the damper will pop off without too much of a fight.
You may find it helpful to apply a few whacks, then rotate the crankshaft in 120* increments, whacking it a few times at each interval (I haven't needed to do this).
It's also helpful to, if possible, shoot a bit of penetrating oil where the damper meets the hub, a day or more in advance of doing the job.
After you get the damper off, clean the damper/hub mating surfaces to remove all corrosion, etc, and apply a very thin coating of anti-seize compound to these surfaces before you reassemble the damper to the hub. This should make it a lot easier to get the damper off next time.
Once the damper is removed, rotate the crankshaft so that one wing of the damper hub is at the six-o'clock position. This will position the other two wings at around the ten- and two-o'clock positions. In this orientation, the Opti will clear the hub as it is being removed/installed.
The Opti basically unbolts and pulls off as you'd expect, once you have the water pump and damper out of the way.
Once the Opti is out of the way, inspect the shaft seals for the Opti, water pump, and crankshaft. If they show any signs of leakage, replace them now.
When you install the new Opti, be sure to align it correctly with the cam gear, and don't force it into place against the timing cover (do NOT use the bolts to draw it into place). At most, give it a gentle bump with the heel of your hand to encourage it to pop into place.
Reassemble everything else.
Follow the cooling system refill procedure in the FSM carefully, and you'll have no problems with this. In particular, be sure to bleed the air out of the system as it's being refilled.
Hope this helps. Best of luck with it.
Live well,
SJW
Posted on: 2007/11/8 21:08
http://www.dynaspark.net/
An interesting read on the front page. It makes me wonder if they bought it back from the guys they sold it to.
The replacement firm was never quite so elequent... I could be wrong, tho.
Posted on: 2007/11/9 2:27
Central Maryland
51 Posts
If I recall correctly, that page has been on their website as-is for at least several months. Seems to me that's the way it read when I last visited some months ago when I got curious about whether or not they were still in business.
Although I've heard no confirmation about it one way or another, I strongly suspect that DynaSpark has gone Tango Uniform as a company. Wonder if anyone's answering the phone there these days...
Live well,
SJW
Posted on: 2007/11/9 16:58
