RICH1994 | FUEL FILTER | ||
HI ALL.IAM GOING TO CHANGE MY FUEL FILTER ON MY 94.BEFORE I DO SOMETHING BAD,I NOTICED IN THE SERVICE MANUAL THAT THERE IS AN O RING ON THE FUEL LINE THAT MIGHT HAVE TO BE CHANGED. I GOT MY NEW FILTER TODAY AND DID NOT SEE AN O RING IN THE BOX.I LOOKED AT THE CORVETTE PARTS CATALOGS AND THEY DO NOT LIST ONE FOR SALE.THANKS FOR ANY HELP.
Posted on: 2010/6/3 1:35
pianoguy | Re: FUEL FILTER | ||
Hi Rich,
I don't recall having to mess with an o-ring on my '96. But then again I may have just erased an unpleasant memory - the job is kind of a PITA ;-) Good luck and be careful! |
Posted on: 2010/6/3 1:39
RICH1994 | Re: FUEL FILTER | ||
Thank you sir for the fast response.I learned today that ordering every nut and bolt from the corvette parts guys isnt always the thing to do.The guys in Florida want about $25 for a filter, and Oreilly sold me one for about $6.00
Posted on: 2010/6/3 1:45
Yep, it always pays to shop around to try to avoid the Corvette tax. I don't recall where I got mine, maybe Jegs.
The job was easier for me as I did it while I was installing headers, which cleared up a little working room. Best to do it when your tank is low on fuel, and make sure to relieve the pressure. Also everyone recommends using line wrenches to avoid rounding off the fittings. |
Posted on: 2010/6/3 1:52
bogus | Re: FUEL FILTER | ||
I remove the filter and line and do the swap outside the car.
Oh, yea, release pressure... remove the cap and vent the pressure at the rail. you will need the plastic line tool to remove the fuel line from the rail. |
Posted on: 2010/6/3 5:50
Weavsvet | Re: FUEL FILTER | ||
What's this bogus? I just take the clip off at the regulator and pull the line out. Got a link to one of these things? |
Posted on: 2010/6/3 11:05
1996 Corvette Coupe,AFR 195 street Eliminators,Edelbrock LT4 Air Gap intake manifold,9.5" 2800 stall,TPIS LT headers,Bullet 226/230.565.565/111 lsa cam,1.7 Scorpion rr's,EWP, X Pipe, Stock Exhaust,Elec.Cutouts,Dana 44/3.45, Tune by Wester's Garage |
Aboatguy | Re: FUEL FILTER | ||
Most chain autopart stores have the Lisle set for cheap....
Posted on: 2010/6/4 0:45
RRTvette | Re: FUEL FILTER | ||
Yeah, it really is a pain in the ass job. I've changed the fuel filter once on my 86 and 95. I took my 95 to get a wheel alignment and they charged me $16 to install a fuel filter. Worth it IMO.
Posted on: 2010/6/4 17:12
Tre57 | Re: FUEL FILTER | ||
Just $16?? Steal! Well worth the money. |
Posted on: 2010/6/4 21:32
Thank you everyone---My car has been sitting for over a year.I put in the gas stableizer,but the gas still smelled old.So after a hose and a mouthfull of gas I think I got it all out of the tank.Didnt even burn the house down(yet).So tomorrow I think Ill tackle the filter.
Posted on: 2010/6/9 22:42
