vis_croceus | (LT1) EGR pipe fitting size? | ||
Need to get a tap and clean up EGR/Air threads on header.
Measured at 7/8-18, but then I search and find that the Camaro LT1 EGR/air fittings are metric, so now I'm doubting my measurement... Anybody know for sure what it is? |
Posted on: 2010/7/14 21:35
94 vert |
vetteoz | Re: (LT1) EGR pipe fitting size? | ||
IIRC 22mm x 1.5
Apparently some later cars had 18 x 1.5 ;same thread as O2 sensor |
Posted on: 2010/7/14 21:45
vis_croceus | Re: (LT1) EGR pipe fitting size? | ||
Thanks.
That corresponds with what I found on the F-body forums - M22 for OBD1 and M18 for OBD2. |
Posted on: 2010/7/14 22:28
94 vert |
I rechecked the thread and it's definitely a -18 not a -1.5
How do you measure diameter on this sort of fitting? Not sure if it's a bolt (OD) or pipe (ID) thread... |
Posted on: 2010/7/15 9:39
94 vert |
BillH | Re: (LT1) EGR pipe fitting size? | ||
Steve,Can you get a mike on the tube nut threads?
An 18 will measure around .670 inch on the major diameter (thread peaks) for a 1.5 thd. and .644 for a 2.5 thd. that's roughly off a chart I saw. Metric threads are slightly smaller than the size indicated, an 18 is 16.4 to 17.1 mm on the diameter. Did you use a thred gage to determine that it's not 1.5? I've onll had a couple out and never checked the threads but they sure felt like a pipe thread when I put them back together (I could be wrong though). |
Posted on: 2010/7/15 13:54
~0.865" = ~22.0mm major diam. Quote:
Yep. And then I drove all over town until I found a place with a 7/8-18 nut to check it with... Also after more googling found out that a lot of US cars EGR are 7/8-18. I think the F-body guys are just forcing an M22-1.5 on there. M22-1.5 and 7/8-18 are close enough that you'd probably just think it was stubborn... |
Posted on: 2010/7/15 18:11
94 vert |
Yea, there some other metric sizes that will accept a US nut,etc. Good Luck |
Posted on: 2010/7/15 21:06
Acquired a 7/8-18 oil drain plug and confirmed fitment.
For those needing a block off plug for EGR/AIR: NAPA BK7041016 Now I just have to buy a $40 tap to fix my $150 headers. |
Posted on: 2010/7/15 22:40
94 vert |
