154 user(s) are online (113 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
corvetteronw L98 distributor
Lowell, MI
I am in the process of SLP intake install with new injectors on my 91. I am also in the "while I'm in there" mode and along with other items I ordered a replacement MSD distributor from Summitt Racing. It came the day after I ordered it! Wow - fast service!
I ordered it on line and saw that it specifically fit the VIN "8" 91 Corvette. This is the L98 and not the LT5.
I have not had time to look at the direction sheet that came with it but I see by looking at the box before I left for work today that it has an adjustable vacuum advance on it. The distributor I took off the car does NOT have an external vacuum advance canister on it. Did they send me the wrong distributor? Or do I just connect a vacuum line to one of the openings in my intake manifold (maybe with a "T" to an existing line?)
Still at work and this is bothering me. Maybe the directions that come with the MSD will tell me what to do.
Posted on: 2010/7/30 1:36
bogus Re: L98 distributor
The LT5 was a lost spark system... no distributor!!!
It should looke identical to what you have, so I would say they shipped the wrong part... shocking... NOT.
Posted on: 2010/7/30 3:03
vetteoz Re: L98 distributor
corvetteronw wrote:
looking at the box before I left for work today that it has an adjustable vacuum advance on it... Did they send me the wrong distributor? .
If it has a vac can ;totally wrong
Computer controlled dist for yours has large 4 wire plug out of dist base which reg HEI ( vac advance or not ) don't have
[IMG]http://i171.photobucket.com/albums/u309/vetteoz/electrical/DSCN2599_ezr2.jpg[/IMG]
Posted on: 2010/7/30 3:23
corvetteronw Re: L98 distributor
Lowell, MI
That is what I needed to know. I will go out to the pole barn and open up the box and look at it.
Thank you!
Posted on: 2010/7/30 13:16
BillH Re: L98 distributor
They shipped what Ron ordered but, it's easy to miss that that distributor had a vacuum advance unless you really look over the part and description.
Can Summit make a mistake, sure so can all the parts houses.
Summit has 50+ damn distriburors listed for a 91, half with vac, half without.
Jegs - 25 distributors listed for a 91 again, half & half.
MSD website says - No distributors available for a 91
Ron, I'd call or email the MSD tech line. I've gotten very good service and quick answers from them. www.msdignitions.com .
Posted on: 2010/7/30 13:17
The only computer control compatible ( full electronic ) dist MSD makes that I am aware off is the MSD # 8366
A small cap remote coil dist identical to the one used in F-Bodies L98's and TBI trucks
[IMG]http://i171.photobucket.com/albums/u309/vetteoz/electrical/msd_8366.jpg[/IMG]
Posted on: 2010/7/30 13:28
Lowell, MI
Traded my old distributor in to NAPA for a rebuilt one. I also added an MSD cap and rotor and an Accell coil. I have to take the cap back as they gave me a clamp on style instead of a bolt down style.
I will be leaving the Tpi cover off now as this will show prettier.
Posted on: 2010/8/2 19:35
CentralCoaster Re: L98 distributor
Yeah, don't trust Summit's catalog as far as you can throw it. I always verify with the manufacturer.
Posted on: 2010/8/3 5:27
Woodstock Re: L98 distributor
Bremen/Germany
369 Posts
No need to, just clip off the clamps and use the screws of your old cap.
Posted on: 2010/8/3 22:45
91 convertible
pr0zac Re: L98 distributor
good luck making that accel coil fit.
Posted on: 2010/8/3 22:52
