117 user(s) are online (57 user(s) are browsing Forums)
parriedog49 WHEEL HOP
24 Posts
HELLO ALL. i have an 85 c4 6 speed and 373 gears, stock springs and shocks, my problem it has realy bad wheel hop, how can i do to fix this
Posted on: 2010/8/28 20:35
Steve40th Re: WHEEL HOP
1114 Posts
Better shocks(see new Bilsteins, or get yours rebuilt), check all rear bushings.
Posted on: 2010/8/28 23:15
Ko'u ohana aia ku'a ikaika
Matatk Re: WHEEL HOP
What Steve said. If you have the original shocks on there they are way past their life expectancy.
Posted on: 2010/8/28 23:46
1Fast04Vert Re: WHEEL HOP
This is your post on another site. Guess it would have helped to have this info here. -
"HELLO TO ALL , when my 85 c4 4+3 trans, 5.7 and 3.08 gears was all stock it would roast the tires, Now the new, 383 stroker, zf 6 speed and 373 gears, it has vilent wheel hop, what can i do to solve this?"
Add better tires to the list as well as more practice in how to launch it correctly. What kind of power are you putting to the ground?
Posted on: 2010/8/29 2:22
zoe6 Re: WHEEL HOP
Northern Indiana
167 Posts
I was under the impression that an independent rear end was not the best choice for hard launch situations and a solid axle was better. So large tire with a taller aspect ratio would help on the launch. But hop will still be an issue since traction bars can not be added to help plant the power to the ground. Shocks will help control the rebound of the springs but probably won't help wheel hop. Just my opinion.
Posted on: 2010/8/29 2:33
Owner of a great Vette! Totally stock ZO6
vetteoz Re: WHEEL HOP
As I noted in his post on SV
As I also noted I have no wheel hop with 420RWHP ( on stock '87 shocks) because I have traction
Posted on: 2010/8/29 2:36
zoe6 Re: WHEEL HOP
Northern Indiana
167 Posts
Whats SV?
Posted on: 2010/8/29 2:40
zoe6 wrote:
Whats SV?
SmokinVette
Corvette Forum for beginners
http://www.smokinvette.com/corvetteforum/forumdisplay.php?f=15
Posted on: 2010/8/29 3:07
zoe6 Re: WHEEL HOP
Northern Indiana
167 Posts
vetteoz wrote:
zoe6 wrote:
Whats SV?
SmokinVette
Thanks for the heads up. The Doctor in charge of our lab come here to read threads and posts. They don't have the time for drama I guess of other sites have. So there is 2 vette sites.
There really is a site for beginners?
Posted on: 2010/8/29 3:12
