pickleusmc | dash issue | ||
i have a 92 coupe and my dash started to mess up on me. just the digital part. first it started to go all haywire and then it started to just turn off then back on. the whole time this happens it blinks "sys" doesnt pop any codes and i am kinda at a loss. now the dash is completly off and it wont come back on. if i could get some advice it would be greatly appreciated.
Posted on: 2010/11/1 23:20
BillH | Re: dash issue | ||
Welcome aboard.
Just to verify, did you check for no codes using a paper clip and the dash buttons? And do you have a FSM? |
Posted on: 2010/11/2 0:13
The FSM basically says to check for CCM codes.
Damn, I just realized you can't read codes if the dash is blank. The only other thing mentioned is an open ground in the wire to instrument panel connector A7, circuit 150. |
Posted on: 2010/11/2 0:27
pickleusmc | Re: dash issue | ||
yeah i have a code reader. and that is what i was using. the anolog parts and the check engine section of the dash still work it is just the digital screen that has stopped working.
Posted on: 2010/11/2 1:20
bogus | Re: dash issue | ||
You need more than a "code reader." You need something that will read the CCM codes.
It sounds like something is amiss with the digital dash. These are VERY durable parts, so I would suggest a bad or weak connection. It is worth trying to remove the IP and seeing if you can check the connections. Does the car sit for extended periods? Do you live in a wet area? |
Posted on: 2010/11/2 1:56
jonszr1 | Re: dash issue | ||
if she sits at all you could have a little mouse problem. i had one chew a ground wire causing 1/2 of my interior light to stop working . a old trick is to get a couple of bars of irish spring and cut them up and place them around inside the car .for some reason the little fella hate that stuff
Posted on: 2010/11/2 2:05
i have removed the instument cluster once to check connections and i even wet as far as using a little 400 grit sand paper to clean up the connectors and it still gave me the same problem, changed nothing it just started getting worse. it was a daily driver untill the digital dash just stopped working. i do live in south carolina by the coast but my friend who has the same year and has been here about the same time has no problems. i thought about that one too.
Posted on: 2010/11/2 21:09
what can i get that will read the ccm codes? the only place i know of here is the chevy dealership. they will charge me and arm and a leg too. what do you mean by remove the "ip" im not familiar with this term or i am and im just being an idiot right now. |
Posted on: 2010/11/2 21:13
paper clip and dash buttons? this one is new to me i have yet to hear about this one. enlighten me please |
Posted on: 2010/11/2 21:27
First, Andy (Bogus) is referimg to the instrument Panel (IP). The connector for the display is on the back. For the paper clip method, go to the upper left on our screen and click "Tech Library" then "Electrical" and "CCM Code Pull". I'd suggest printing it out and putting it in your garage. You will use it from time to time (after your dash is back to normal). It does sound like a problem with the connection or the ground but you won't know until you get in there. If you do take it apart, I may be able to scan the 92 FSM connector pic which shows where the ground is in the connector. |
Posted on: 2010/11/2 22:09
tjpreul | Re: dash issue | ||
I was given a set of ALDL plugs from the PO that were bought from Killebrew. The plugs have pins installed with jumpers. It says this will work for 90-93. It sounds lazy, and it is. Although it is nice when I want to look for codes. |
Posted on: 2010/11/3 0:25
I have the same plugs. They are so easy to use!
Posted on: 2010/11/3 1:26
thanks for the help im going to be tearing into it this weekend ill let you know if i get it fixed or not.
Posted on: 2010/11/3 16:51
if your gonna buy a fast car, drive it like a f*kin fast car. |
If you run into an issue, lemme know, I have the Helm manual for 1992.
Posted on: 2010/11/3 18:29
fox_guy48 | Re: dash issue | ||
Mine is doing the same thing but i smack the top of the dash and it starts working again im pretty sure its a bad connection i will be pulling the ip eventually weather been bad over here in germany no garage.
Posted on: 2010/11/7 13:27
92 Polo Green, MSD Ignition, 1.6 roller rockers, TPIS Headers, Exhaust, Airfoil, Stage 2 Chip. |
