167 user(s) are online (122 user(s) are browsing Forums)
Sheet Molded Compound.
The onl...
Dale1990 Clutch slave bolt holes stripped
Conway, AR
128 Posts
It looks as though some combination of dumbness between myself and a previous owner has left me with both of the clutch slave cylinder bolt holes stripped out. I guess that explains the weird shifting.
Is there a way to fix this w/o removing the transmission?
Thanks!
Posted on: 2010/11/6 19:52
pr0zac Re: Clutch slave bolt holes stripped
just tap it the next size bigger. drill the holes on the slave if needed
Posted on: 2010/11/6 20:11
Dale1990 Re: Clutch slave bolt holes stripped
Conway, AR
128 Posts
Would I need to drill the holes in the housing to tap them to the next size? I'm not sure there is enough room to get a drill in there.
Posted on: 2010/11/6 20:30
bogus Re: Clutch slave bolt holes stripped
you may need a 90* angle drill.
Posted on: 2010/11/6 21:56
Conway, AR
128 Posts
I'll give that shot. Thanks all!
Posted on: 2010/11/8 20:42
86 Coupe: SR 383
90 Convertible: Stock L98
06 Z06: Stock LS7
