iCorvette | If the front lower shock bushing is torn, is there a cheap fix? | ||
well I got some new shocks coming, and I was hoping to sell my low mileage FX3 (~35k) shocks...
however when installing my lower sway bar poly bushings ( what a bitch) I notice one of them was ripped. is this repairable economically or should I just toss the shocks in the garbage? |
Posted on: 2010/12/17 19:45
BrianCunningham | Re: If the front lower shock bushing is torn, is there a cheap fix? | ||
Try contaccting bilstien
Sounds like you found out why you don't like them |
Posted on: 2010/12/17 20:13
iCorvette | Re: If the front lower shock bushing is torn, is there a cheap fix? | ||
I don't like the FX3 which threw a bad rr broken gear code and others...the fx3 sucks, so I sold every part of it over a 2 year period, these shocks are the last to go....bye bye
just called them 12 bucks, and a vise.... |
Posted on: 2010/12/17 20:20
1Fast04Vert | Re: If the front lower shock bushing is torn, is there a cheap fix? | ||
Don't throw them away. You would be surprised how quickly you can sell them on ebay or CF.
Posted on: 2010/12/17 20:33
bogus | Re: If the front lower shock bushing is torn, is there a cheap fix? | ||
I agree. The bushings are cheap.
Posted on: 2010/12/17 21:10
SpectatorRacing | Re: If the front lower shock bushing is torn, is there a cheap fix? | ||
Which bushing? I have scores of them for the Bilsteins. If they're the same I can send you one. Post a pic...
Posted on: 2010/12/17 22:10
aka Scaryfast |
Thanks for your generality.. but I am getting non FX3 shocks... |
Posted on: 2010/12/19 19:01
