BrianCunningham | Speaking of w3ird connectors | ||
Posted on: 2011/1/2 20:04
biggrizzly | Re: Speaking of w3ird connectors | ||
Electrical stuff in these cars is getting really old too. I have cracked several connectors and will need to replace them. Last year I replaced the passenger side window switch. That was about $75. I guess that was a cheap part.
Posted on: 2011/1/2 20:51
bogus | Re: Speaking of w3ird connectors | ||
Wow. I had a power door lock harness break. I replaced it with one from a junk yard for a couple of bucks.
That looks like someone took the time to fix the wiring, but not the harness. Seems a bit short sighted to me. It isn't OEM, I have a connector on my 92. |
Posted on: 2011/1/2 20:54
BrianCunningham | Re: Speaking of w3ird connectors | ||
Car only had 20k on it when I bought it.
1st time it's been apart. |
Posted on: 2011/1/2 21:29
1st time YOU know about. Really... 20k miles is long enough for some hack to do damage.
A friend of mine bought a TransAm a few years back... it has 20k on it... and the trans AND rear end were blown out. Yea, 20k miles... 1/4 mile at a time. |
Posted on: 2011/1/2 21:37
Woodstock | Re: Speaking of w3ird connectors | ||
I had a power door lock harness break To me it looks more like the up/down switch for the window. IIRC mine looks just like it. |
Posted on: 2011/1/2 22:29
91 convertible |
That's the one What did yours look like Bogus? |
Posted on: 2011/1/2 22:43
BillH | Re: Speaking of w3ird connectors | ||
Is there clear, rubber tubes (insulators) over each wire ?
IIRC, mine's like that. |
Posted on: 2011/1/2 23:26
mseven | Re: Speaking of w3ird connectors | ||
mine looks the same
Posted on: 2011/1/3 15:42
I will have to pop it out... I don't remember what I mine looks like, but it is a connector. The wires don't come out individually.
Posted on: 2011/1/3 18:14
So, it's stock then?
OK like I said w3ird! |
Posted on: 2011/1/4 2:42
