110 user(s) are online (57 user(s) are browsing Forums)
BrianCunningham Speaking of w3ird connectors
When I replaced my door regulators, look what I found
Photobucket
I've need seen individual wire hookups like that, not mate & lock, on a production car.
Posted on: 2011/1/2 20:04
biggrizzly Re: Speaking of w3ird connectors
Electrical stuff in these cars is getting really old too. I have cracked several connectors and will need to replace them. Last year I replaced the passenger side window switch. That was about $75. I guess that was a cheap part.
Posted on: 2011/1/2 20:51
bogus Re: Speaking of w3ird connectors
Wow. I had a power door lock harness break. I replaced it with one from a junk yard for a couple of bucks.
That looks like someone took the time to fix the wiring, but not the harness. Seems a bit short sighted to me. It isn't OEM, I have a connector on my 92.
Posted on: 2011/1/2 20:54
BrianCunningham Re: Speaking of w3ird connectors
Car only had 20k on it when I bought it.
1st time it's been apart.
Posted on: 2011/1/2 21:29
1st time YOU know about. Really... 20k miles is long enough for some hack to do damage.
A friend of mine bought a TransAm a few years back... it has 20k on it... and the trans AND rear end were blown out. Yea, 20k miles... 1/4 mile at a time.
Posted on: 2011/1/2 21:37
Woodstock Re: Speaking of w3ird connectors
Bremen/Germany
369 Posts
To me it looks more like the up/down switch for the window. IIRC mine looks just like it.
Posted on: 2011/1/2 22:29
91 convertible
That's the one
What did yours look like Bogus?
Posted on: 2011/1/2 22:43
BillH Re: Speaking of w3ird connectors
Is there clear, rubber tubes (insulators) over each wire ?
IIRC, mine's like that.
Posted on: 2011/1/2 23:26
mseven Re: Speaking of w3ird connectors
Motor City Madhouse
247 Posts
mine looks the same
Posted on: 2011/1/3 15:42
I will have to pop it out... I don't remember what I mine looks like, but it is a connector. The wires don't come out individually.
Posted on: 2011/1/3 18:14
So, it's stock then?
OK like I said w3ird!
Posted on: 2011/1/4 2:42
