181 user(s) are online (103 user(s) are browsing Forums)
jmartynuska Front Spring Seat Lube
Rindge, NH
51 Posts
I'm getting ready to swap out the front spring. What, if anything, should I use to lube the a-arm seat, or should I just make sure it's really clean?
Any other tips/hint/suggestions would be appreciated as well.
TIA...
Jeff
Posted on: 2012/2/28 19:48
'89 Z51/'02 Z06
45/145BS NER SCCA
1Fast04Vert Re: Front Spring Seat Lube
Just clean, no lube.
Posted on: 2012/2/28 21:40
BillH Re: Front Spring Seat Lube
Yep.
If you lube it - the lube gets dirty- dirty lube acts like a grinding paste.
Posted on: 2012/2/29 0:17
jmartynuska Re: Front Spring Seat Lube
Rindge, NH
51 Posts
Just cleaning it will be then.
Thank you for the replies!
Posted on: 2012/2/29 17:11
'89 Z51/'02 Z06
45/145BS NER SCCA
