440 user(s) are online (347 user(s) are browsing Forums)
Ultraman C5 DRL Replacement.........LED'S?
15680 Posts
The daytime running light sockets on my 02 are burnt and melted a bit and I can't keep the bulbs working on the passenger side. I know Tom replaced his entire front units awhile back but I am thinking new sockets or to replace with LED's......any help?
I do have a Dorman part number 85882 but the listing says turn stop sockets and this is for the DRL's and may work ok for those........
Posted on: 2012/4/3 18:22
bogus Re: C5 DRL Replacement.........LED'S?
have you considered ditching the entire popup setup? The C5R light kits are killer better than the stock bricks.
Just a thought.
Check with corvettehid.com. He has a ton of stuff.
Posted on: 2012/4/3 19:18
NC Kid Re: C5 DRL Replacement.........LED'S?
North Carolina
1671 Posts
Leds/HIDs anything but halogen. They last longer, brighter, safer and I love mine!
Posted on: 2012/4/3 21:01
teebee Re: C5 DRL Replacement.........LED'S?
12844 Posts
Marcus, my corner lights were burned some, and I replaced the entire corner lights.
LEDs are a viable solution. I'll see if I can find where to get them. I know there are vendors.
Posted on: 2012/4/4 13:16
12844 Posts
Marcus, you can get your LED DRLs here. These are White DRLs instead of amber. These LEDs will cause hyperflash on the turn signals and a harness to cure that problem is available too.
http://shop.jwmotoring.com/product.sc?productId=239&categoryId=4
Posted on: 2012/4/4 14:56
Ultraman Re: C5 DRL Replacement.........LED'S?
15680 Posts
Thanks TBee....I already have the harness in place to cure the turn signal problem that is common in the C5's. I'll take a look.
Posted on: 2012/4/4 15:10
BillH Re: C5 DRL Replacement.........LED'S?
Neon's good......and some of them wheels that keep spinning when you come to a stop.
Posted on: 2012/4/4 16:28
Not to be silly, but I am a fan of LEDs. They use less current, put less of a load on the electrical system (which is already overtaxed) and last longer.
You call that bling, I call that a good idea.
Posted on: 2012/4/4 16:30
Not me, I was just harassing Marcus.
I like LED's.
I've used them a long time, built an overhead console in Chev Van in 1980 with 12v LEDs in it for the high beams & turn signals. I also build LED "rain lights" for the racecars.
Posted on: 2012/4/4 16:50
15680 Posts
Already got those on the Vette......gottum from these guys.....ummm may contain some bad words but its hard to tell......
Posted on: 2012/4/4 17:51
I have seen that parking lot before... if I am right, it's in Orlando... and I think I have been there. It just looks so damned familiar.
Posted on: 2012/4/4 18:15
