jonszr1 | hi guys i really need your help on a hei thing i think | ||
we just put a motor in a 89 firebird . started just fine . ran it for a little while turned it off to ck for leaks . then went to start it and poof nothing . turns over but no spark . wtf what do I ck for . it is a 350 .please help it is a xmas present for a buddys grandson
Posted on: 2014/12/24 23:31
Matatk | Re: hi guys i really need your help on a hei thing i think | ||
How did you verify no spark? No spark at the plug?
Posted on: 2014/12/25 2:25
Posted on: 2014/12/25 2:35
josephf31 | Re: hi guys i really need your help on a hei thing i think | ||
Check distributor rotor, wires, etc. first
Posted on: 2014/12/25 16:02
2002 Magnetic Red C5 6 spd LS1 convertible |
bogus | Re: hi guys i really need your help on a hei thing i think | ||
if it has an external coil, make sure the leads are clean and good.
Posted on: 2014/12/27 1:11
LD85 | Re: hi guys i really need your help on a hei thing i think | ||
make sure the fuel pump cycles upon turning the ignition on / but before you crank the engine.
test for spark by pulling a plug wire and putting a spark plug into the plug wire and setting the end of the plug onto steel so it is grounded |
Posted on: 2014/12/27 23:17
2005/Z51 |
