pianoguy | Recommend me some jack stands | ||
I have some old rickety 3-legged stands that I don't trust, so I'm going to get some new ones before I start working on the car this spring. I'll be pulling the exhaust and installing headers, so I need adequate clearance to work under there (I'm reasonably slim). I don't want to spend an arm and a leg, but also don't want said arms and legs squashed. Any particular brand or size I should look at, or shy away from?
Thanks! |
Posted on: 2008/1/29 23:12
MK 82 | RE:Recommend me some jack stands | ||
Recently bought four 6 ton stands at Pep Boys that I am pleased with. The larger capacity stands will allow you to get the car higher.
Posted on: 2008/1/29 23:24
96 CE Roadster LT4 |
movnviolation | RE:Recommend me some jack stands | ||
As Droptop said Pep Boys. I bought some from Sears that are heavy duty. Not expensive! Been under the car with them alot. I still put blocks under the wheels however. Seen the results of cars comming down. Not pretty!
Posted on: 2008/1/30 5:26
skirlin | RE:Recommend me some jack stands | ||
I've heard that the stands to go for are the 12 ton stands from harborfreight.com. They are currently $70 for a pair. I will be buying some very shortly and I would also be interested in anyones feedback on stability and price. I am rather paranoid about safety. I have used concrete blocks in the past but have read that was a very bad idea. Learning something new everyday.
Posted on: 2008/1/30 6:41
There is no point in living if you can't feel alive. |
FATED | RE:Recommend me some jack stands | ||
I use 4 of the Harbor Freight stands. They are O.K. I don't trust any stands so I always leave the jack under it and smaller stands to insure tht there is a wide crush zone.
Posted on: 2008/1/30 19:41
