158 user(s) are online (96 user(s) are browsing Forums)
cmashark steering rack questions
virginia beach, va
74 Posts
hey everyone,
i have an 87 coupe and i think the steering rack is suffering from morning sickness. has any of you rebuilt your own racks? i have found rebuild kits for our racks and was thinking about trying it out.....
chris
Posted on: 2008/2/4 1:25
1987 Coupe 2 tone white/silver, auto, Z52.
bone stock, except for Flowmaster catback and precats eliminated.
bogus RE:steering rack questions
20861 Posts
gee... no... considering that remanned ones are so cheap, I never considered going inside.
Are you sure the belt isn't getting soaked with antifreeze??
Posted on: 2008/2/4 1:54
NC Kid RE:steering rack questions
North Carolina
1671 Posts
Are the remanufactured ones reliable? Midamerica sells them but so does autozone...
Posted on: 2008/2/4 2:27
cmashark RE:steering rack questions
virginia beach, va
74 Posts
it would only save about $100, but i can pick the rebuild kit up locally or i would have to order a rack, mail the core back, wait for a credit.....
the belt looks good....the steering wheel doesn't want to move much when i first start it, but after a few minutes idling, it works. i have no growling from the pump.
Posted on: 2008/2/4 2:35
CentralCoaster RE:steering rack questions
gee... no... considering that remanned ones are so crappy, I never considered going inside.
Edited for truth.
The autozone and even Delco reman racks are garbage overseas stuff. I bought mine from Meridian auto parts, they're a domestic remanufacturer. I had it side by side with the misboxed autozone rack, and the quality difference was obvious, so I assume the same for the quality of parts and labor on the inside of the rack too.
It costed me more, but I didn't like the idea of going back in to change the rack a 2nd time, even with the warranty. Good parts don't need a good warranty.
Before the swap, verify it's the correct ratio by turning the input with a crescent wrench. The Z51 racks should be 2 turns lock to luck.
I removed the rack by fishing it out the drivers side, had to disconnect the swabar.
Also I put a new pump and filter in at the same time so the rack wouldn't be contaminated with metal from the old one.
Someone recommended adding Lucas to cure the morning sickness, but it made mine 10x worse and finished off the dying rack. That fluid is way to thick to be pumped through the PS system, IMO.
Anyhow when you buy a reman rack you are essentially paying for a rebuild service, since you return your original as a core.
There are no new racks available, only remans.
Posted on: 2008/2/4 21:17
