217 user(s) are online (185 user(s) are browsing Forums)
1st Gear: 2.74
2nd Gear: 1.57
4th Gear: 0.67
Reverse: 2.06
ironcurtain White Smoke from Valve Covers?
39 Posts
Hey guys,
Today I was doing some minor projects on my car when I decided to turn it on and rev it up a little. I reved it up and down and when I got into higher RPMs white smoke entered the car.
I popped the hood open and while I was looking I revved my car again and noticed the white smoke was coming around the passenger side valve cover. I did post up an issue with oil possibly leaking around that area.
Could the valve cover gaskets be the problem? the white smoke seemed to be coming around the valve cover area from what I could see.
Another thing was that I have LT4 roller rockers and im using my old valve covers. I havent really noticed an issue with cleareance but its hard to explain but one or two of the valve cover bolts have oil around the bolts. kind of confused about this. I have been losing quite a bit of oil somehow so maybe that might be the problem
My friend told me to put some kind of sealant around the gasket and valve cover in order to seal it up but not sure what to do about the bolts.
Any help would be great! thanks.
Posted on: 2008/2/18 1:48
1995 Aqua Metallic Corvette. LT4 Hot Cam, Ported Heads, 3.73 Gears, Edge Torque Converter, Long Tube Headers, and X-Pipe.
bogus RE:White Smoke from Valve Covers?
it sounds like the rubber grommets on the bolts have given up the ghost.
you have a valve cover leak... get a new gasket set and replace. the grommets will come with the gasket set.
Posted on: 2008/2/18 2:15
ironcurtain RE:White Smoke from Valve Covers?
39 Posts
have any idea where I can order a new gasket set for my LT1?
and btw how does that happen? just wear? and could that explain losing a lot of oil? thanks!
Posted on: 2008/2/18 2:17
39 Posts
Hey guys quick question. of curiosity could the white smoke that comes out be blowby? And wouldn't that be a lot of blowby?
Posted on: 2008/2/19 4:35
jaa1992 RE:White Smoke from Valve Covers?
Stone Mtn, GA (near Atlanta)
187 Posts
Good farkin luck! I tried Summit Racing - 2 weeks for delivery
NAPA - we don't carry it, can't order it
I'm still looking, my original 120K valve cover gaskets are going back on if I can't find a set by Friday
Posted on: 2008/2/19 16:25
fnsblum RE:White Smoke from Valve Covers?
Nothern Utah
32 Posts
There is a tube on that side that the PCV system used for inlet air. It runs from the throttle body back the the intake manifold. There is a rubber grommet on the end of the tube. Make sure the tube is plugged in and the grommet is not worn out. I would also check the PCV valve for proper operation. It is on the driver side under the injector cover. Later! Frank
93 Red LT-1
Bought in Nov.
First mod is a set of Magnaflows.
dan0617 RE:White Smoke from Valve Covers?
try Jegs
Posted on: 2008/2/19 23:28
it's not fair, but the 1992 LT1 uses different valve cover gaskets. We can use conventional valve cover gaskets. Also, call Chris May at Superior Chevy, 1.800.728.8267 (tell him C4 Guru sent ya) and get a gasket set from him.
Also, NAPA used to stock the kit, from FelPro, for the 93-97 LT1.
Posted on: 2008/2/20 2:56
CentralCoaster RE:White Smoke from Valve Covers?
It sure can be. Can you see more carefully where it's coming from?
Posted on: 2008/2/26 5:18
cmashark RE:White Smoke from Valve Covers?
virginia beach, va
74 Posts
is this an LT1 thing? i just installed a new set of gaskets for my VC's (L98 with centerbolts) and the didn't come with grommets. ther wasn't any grommets when they came off either
Posted on: 2008/2/26 5:33
1987 Coupe 2 tone white/silver, auto, Z52.
bone stock, except for Flowmaster catback and precats eliminated.
Oh, there's grommets, they're probably just so rock hard from age that you thought they were plastic, or maybe they're even painted over.
Posted on: 2008/2/26 7:18
