232 user(s) are online (175 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
LD85 C5 Brake Upgrade
Indianapolis, Indiana
784 Posts
I know, it has been done many times before, just wanted to document the lower cost for parts.
Rock Auto C5 Rotors = $50 shipped ($20.99 each)
14x2 mm Bolts = $10.00
C5 Calipers, Brackets & Pads = $190 shipped
SS braided brake lines = $100
Conversion brackets made by me = $0
Since these are NOT Z06 Calipers, I have to paint them the color of my choice
So I painted them w/ RED & Black caliper paint and left the lettering silver, then clear coated w/1200-degree clear,, painted the retro-brackets too
Posted on: 2008/3/3 13:34
2005/Z51
smooth Re: C5 Brake Upgrade
Formerly "Aquavet" in Pa.
386 Posts
Did you strip them all the way down to bare metal, or just spray with brake cleaner?
Posted on: 2008/3/3 14:59
Alan
2001 Navy Blue Metallic
LD85 Re: C5 Brake Upgrade
784 Posts
Yes, I just cleaned them well with Brake Cleaner and sprayed them with Hi Temp engine paint
Posted on: 2008/3/3 15:03
2005/Z51
386 Posts
Came out nice. I've got a set I have to rebuild first, then paint and bolt up.....its on the "to do" list
Posted on: 2008/3/3 15:25
Alan
386 Posts
Thanks for getting me off my ars LD !! Got some black caliper paint and went at it ! Going to let it cure overnight before I clean up the logo with some emery paper.
Thanks again LD
Posted on: 2008/3/3 21:17
Alan
784 Posts
No problem, I used a razor blade and cleaned up the lettering,,,
then dont forget to clear coat the Caliper when you are done. I used 1200 degree clear engine paint.
Posted on: 2008/3/3 21:39
2005/Z51
SpectatorRacing Re: C5 Brake Upgrade
I painted mine a long time ago, but when they got covered in dust I cleaned them with brakecleen and it removed all the paint, too.
Would clear coat protect against cleaners?
Posted on: 2008/3/5 19:02
rickreeves1 Re: C5 Brake Upgrade
New Orleans
96 Posts
Were all the parts bought from Rock Auto?
Posted on: 2008/3/5 19:19
784 Posts
The 1200 degree ceramic clear coat helped to prevent chipping and is much easier to keep clean, I have not used chemicals on them, have not had to so far...
The rotors are from RockAuto,,, but I got the Calipers and pads from a guy on CF.
Posted on: 2008/3/6 1:57
2005/Z51
