NC Kid | So whats left | ||
Routine tune up this weekend!
Injector cleaner Spark plugs Brake pads Flush radiator Clean maf sensor Replace radiator hoses/clamps Thermostat/gasket(not a 160*) Clean throttle body Fuel filter Flush brake system(thanks to the thread posted) Flush power steering fluid Wiper blades Check timing Check cap/rotor New front tires Check transmission fluid Clean car/engine bay Have rotors turned Replace radiator cap(its over a year old) Serpentine Belt Tighten Lugnuts Air Filter Completed in the last month: Gas cap A.C. recharged Oil/filter Wires Anything I over looked? |
Posted on: 2008/7/9 1:06
pappyfreebird | Re: So whats left | ||
title to pappy????
Posted on: 2008/7/9 1:21
Z51L9889 | Re: So whats left | ||
Put gas in it and drive the wheels off it!
Posted on: 2008/7/9 1:28
bogus | Re: So whats left | ||
you are assuming that it will run after he is done.
just be damned sure the computer and cable modem are working... |
Posted on: 2008/7/9 1:43
NC Kid | Re: So whats left | ||
What does that mean? |
Posted on: 2008/7/9 1:47
Randy93 | Re: So whats left | ||
PCV???
Vacuum lines checked??? Some Seafoam?? |
Posted on: 2008/7/9 2:04
TommyT-Bone | Re: So whats left | ||
For the ride .......
Clean the keys with alcohol. Makes sure there is nothing under the seats or compartments that you don't want there. License,registration,AAA and insurance card. Travel type tool box and a fire extinguisher. Major credit card and a cell phone. I'm sure I'm forgetting something. |
Posted on: 2008/7/9 2:33
me being a smart ass... implying that if it doesn't start, you will be back here asking for help... as for what else? just take your time and do one thing at a time. It will make the project go that much smoother. When you clean the engine, use Simple Green. It is far less nasty than any other engine cleaner and just as effective. I would go over each connector and hit it with lithium white grease. This will help keep moisture out of the connectors... and this is important as the connectors age. |
Posted on: 2008/7/9 5:21
runner140 | Re: So whats left | ||
You will be asking for help? |
Posted on: 2008/7/9 11:35
96, white and a ton of miles. Somewhat stock. |
Matatk | Re: So whats left | ||
1) Lambo doors 2) neon underbody lights Matthew |
Posted on: 2008/7/9 13:14
P.S. shut the hell up |
Posted on: 2008/7/9 15:35
