JimD | U joints (driveshaft) | ||
Do I have to drop the exhaust, and x member to remove the driveshaft. I need new U joints, thanks Jim.
Posted on: 2008/10/14 22:55
bogus | Re: U joints (driveshaft) | ||
yes. You also will have to loosen the c-beam. I don't think there is enough room to drop the shaft with the beam in place.
Posted on: 2008/10/15 1:58
Jeffvette | Re: U joints (driveshaft) | ||
You can modify underneath to remove the drive shaft with out touching the C-beam.
Posted on: 2008/10/15 2:25
vetteoz | Re: U joints (driveshaft) | ||
Mine comes out the side fine without touching C beam. Disconnect uni caps , slide shaft foward to clear yoke; requires wheels off ground so you can rotate diff yoke to free uni's. Slide out and backover handbrake cable until front yoke free. Slide foward and down to drop |
Posted on: 2008/10/15 4:26
CentralCoaster | Re: U joints (driveshaft) | ||
I've worked on some C4s that did and some that don't.
Mine doesn't. There must be variations in how big the sheetmetal edges are under there. I assuming that's what Jeffvette is talking about trimmin down. |
Posted on: 2008/10/15 15:27
