jim420 | The answer to GM's troubles | ||
Bring her back
Attach file: 099e_18.JPG (7.25 KB) |
Posted on: 2008/12/30 2:54
The Benevolent Stranger |
crash | Re: The answer to GM's troubles | ||
you say that now. have you ever put a starter in one of these. they were a real work of art
Posted on: 2008/12/30 3:03
IM NOT COMPLETELY USELESS I CAN BE USED AS A BAD EXAMPLE |
BrianCunningham | Re: The answer to GM's troubles | ||
Posted on: 2008/12/30 3:17
bogus | Re: The answer to GM's troubles | ||
The Chevette is why GM is in the boat it's in... uh-huh.
Posted on: 2008/12/30 4:18
pianoguy | Re: The answer to GM's troubles | ||
Chevette must be French for 'turd'. I had to rent one of those one time - I swear I could get out and run faster.
Posted on: 2008/12/30 13:20
Schrade | Re: The answer to GM's troubles | ||
I rented one one time too for an NC-to-Maine trip. Wasn't too bad for travel, considering how my CJ-7 would have been on my back, on gas, ... |
Posted on: 2008/12/30 13:57
