bogus | Does anyone make a caliper rebuild kit? | ||
I have the best C4 calipers made - the GrandSport units.
They have been in place since 2001 - 80k miles or so. I would like to reseal them... anyone make the kit? Thanks! |
Posted on: 2009/1/19 7:17
Jeffvette | Re: Does anyone make a caliper rebuild kit? | ||
GM. Autozone may have it under a mustang cobra rebuild kit.
Posted on: 2009/1/19 8:03
sidney004 | Re: Does anyone make a caliper rebuild kit? | ||
Should be readily available at any parts store, here are the part numbers from Rockauto:
Item Price Core Total Advice BENDIX Part # 66288 More Info Front [Wholesaler Closeout -- 30 Day Warranty (Only 8 Remaining)] $5.25 $0.00 $5.25 Add to Cart RAYBESTOS Part # WK2004 More Info {Professional Grade} Front Part Image $6.20 $0.00 $6.20 Add to Cart ACDELCO Part # 18H170 More Info {replaces 18031644 #18031644, 19203661} CALIPER KIT,FRT BRK DURASTOP; 2 DOORS; 1-1/2IN CYL BORE CALIPER KIT,FRT BRK DURASTOP; CONVERTIBLE; 1-1/2IN CYL BORE Part Image $7.56 $0.00 $7.56 Add to Cart DORMAN Part # D352004 More Info {First Stop #10104486, 12520229, 12520230, 12520231, 12520232, AW346529, AW349942, F4ZZ 2221-A} Front; Bore = 1-1/2" * Non-stock item--shipping delayed up to 2 business days |
Posted on: 2009/1/19 8:09
bogus | Re: Does anyone make a caliper rebuild kit? | ||
I honestly didn't know anyone made the kit.
I will check into that... Cobra brakes, duh, Baer might even offer something. Thanks! |
Posted on: 2009/1/19 15:33
BrianCunningham | Re: Does anyone make a caliper rebuild kit? | ||
Stainless steel brakes will have them too.
You can upgrade the pistons while your at it. If you go on a road course, they'll help with heat. |
Posted on: 2009/1/19 16:56
vetteoz | Re: Does anyone make a caliper rebuild kit? | ||
bogus wrote: GrandSport units. I would like to reseal them... anyone make the kit? The caliper kit is the same for the std JL9 12" brakes and the 13" J55 /GS brakes |
Posted on: 2009/1/22 6:47
