168 user(s) are online (82 user(s) are browsing Forums)
movnviolation Wheel center cap locking bolts, Help
Hesperia, Calif
188 Posts
I am trying to find a source for a set of security bolts for the 89 stock wheel hubs. Any ideas.
Ecklers, Corvette america, etc, don't have them.
Any ideas?
Had to drill one, key became worn.
Posted on: 2008/5/2 19:03
Mods
CentralCoaster Re: Wheel center cap locking bolts, Help
Sounds like a junkyard item... dino's corvette salvage or maybe vette2vette
Posted on: 2008/5/2 19:25
rayquayle Re: Wheel center cap locking bolts, Help
139 Posts
Time for the segment we call "Little Known Corvette Facts".
These locks were manufactured by McGard. The original owner would have gotten one of these:
And a registration card something like one of these:
The registration card is obviously the important part as the Instructions are pretty self explanitory. I'm pretty sure you can still order the Keys and Locks from McGard. I suspect you don't have the registration so I guess you'll have to contact McGard and either buy a new set of 4 locks with key or send them a good key to get a replacement.
Try this link.
Posted on: 2008/5/3 7:25
Ray Quayle in England
'86 Indy PaceCar, 4+3
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
movnviolation Re: Wheel center cap locking bolts, Help
Hesperia, Calif
188 Posts
Thanks Ray, but already tried them. Can't help me!
Posted on: 2008/5/3 12:15
Mods
139 Posts
This worries me as I don't have a spare set. When you say McGard can't help you, what exactly do you mean? They no longer do these or they can't help you without a registration #?
Posted on: 2008/5/3 17:55
NCM Founder #2896
NCM Lifetime #672
Hesperia, Calif
188 Posts
Tried to get a new set and was told that they no longer have them. Either my key is stripped or a bolt is. Had to drill and use easy out.
If you find out something diff. please let me know. I am using allen head bolts.
I am the second owner and have not found the code paper work.
Posted on: 2008/5/3 20:20
Mods
Matatk Re: Wheel center cap locking bolts, Help
22812 Posts
I'm surprised an aftermarket company hasn't started making these yet. Hopefully it will be soon as more people start restoring the C4s.
Keep us posted if you find anything
Posted on: 2008/5/3 23:21
