Curtis1974 | Will these fit my 1995? | ||
I'm looking at a new tire and wheel package for my 1995 and was wondering if the following sizes will fit without rubbing?
Front 17 x 9.5 - 56mm offset / Rear 18 x 10.5 - 56mm offset Rear 295 35 zr18 / Front 265 40 zr17 Thanks. |
Posted on: 2009/8/10 9:42
Fluff | Re: Will these fit my 1995? | ||
I don't know if my 93 has the same clearances as a 95 (perhaps not!)?,
I run 18x10.5 (58 ET) with 275/40 ZR18 (no spacers) on the rear and this setup has rubbed a slot in the lower rear part of the plastic shroud inside the wheel well. All mechanical parts clear, but I guess I'm just over the limit for full clearance. Although within safety specs, I reckon my wheels look too wide for the tyres and given the finances I'd like to go smaller wheels in the future. Don't know about the fronts as I'm on 18's there too (245/40 x 18). |
Posted on: 2009/8/10 10:51
93 LT1 Coupe. |
bogus | Re: Will these fit my 1995? | ||
Yes. If it fits a 93, it will fit a 95. No problem.
You can also confirm the fitment via tirerack.com. Remember, they are Guru sponsers!!! |
Posted on: 2009/8/11 4:18
vetteoz | Re: Will these fit my 1995? | ||
Posted on: 2009/8/11 4:51
CentralCoaster | Re: Will these fit my 1995? | ||
Yeah, it'll fit.
Posted on: 2009/8/11 17:28
Curtis1974 | Re: Will these fit my 1995? | ||
Thanks guys. When I save up a little scratch I'll get these. As soon as I do I'll post some pictures. Again, thanks for the help!
Posted on: 2009/8/12 4:19
Car's approximate birthday: June 29, 1974 Purchase date: 11/23/2003 Custom candy green - Vortec roller motor - TT2's - Custom sound system - Hooker side pipes - Babe magnet :thumbleft: |
