135 user(s) are online (95 user(s) are browsing Forums)
Very stout.
Curtis1974 Will these fit my 1995?
Bolingbrook, IL
1070 Posts
I'm looking at a new tire and wheel package for my 1995 and was wondering if the following sizes will fit without rubbing?
Front 17 x 9.5 - 56mm offset / Rear 18 x 10.5 - 56mm offset
Rear 295 35 zr18 / Front 265 40 zr17
Thanks.
Posted on: 2009/8/10 9:42
Fluff Re: Will these fit my 1995?
Winchester UK & Alicante ES
247 Posts
I don't know if my 93 has the same clearances as a 95 (perhaps not!)?,
I run 18x10.5 (58 ET) with 275/40 ZR18 (no spacers) on the rear and this setup has rubbed a slot in the lower rear part of the plastic shroud inside the wheel well. All mechanical parts clear, but I guess I'm just over the limit for full clearance.
Although within safety specs, I reckon my wheels look too wide for the tyres and given the finances I'd like to go smaller wheels in the future.
Don't know about the fronts as I'm on 18's there too (245/40 x 18).
Posted on: 2009/8/10 10:51
93 LT1 Coupe.
bogus Re: Will these fit my 1995?
20861 Posts
Yes. If it fits a 93, it will fit a 95. No problem.
You can also confirm the fitment via tirerack.com. Remember, they are Guru sponsers!!!
Posted on: 2009/8/11 4:18
vetteoz Re: Will these fit my 1995?
Posted on: 2009/8/11 4:51
CentralCoaster Re: Will these fit my 1995?
Yeah, it'll fit.
Posted on: 2009/8/11 17:28
Curtis1974 Re: Will these fit my 1995?
Bolingbrook, IL
1070 Posts
Thanks guys. When I save up a little scratch I'll get these. As soon as I do I'll post some pictures. Again, thanks for the help!
Posted on: 2009/8/12 4:19
Purchase date: 11/23/2003
