155 user(s) are online (106 user(s) are browsing Forums)
pappyfreebird pheasent huntin
1028 Posts
fergot me tech 9 ,,,so i hadda simply scream like a fuggan wild banshee n scare em outta the ditch n hit em at 75 mph...thank the brutha upstairs it ony made front tire chirp a bit n bent my 3/8ths bolt n 3/16ths plate steel that hold me ditch lights on..that ony took bout 1/2 hr to repair..n me pappy is gonna enjoy the bird..brutha snake perched it noicely on front end..i held him proper like..he said fug mayun the fethars were evo where (he was behind me)
Posted on: 2008/10/23 11:45
pianoguy Re: pheasent huntin
Some years back a big one flew out of the ditch just a few feet in front of me - it was his last flight, and didn't do the grille of my truck much good.
Posted on: 2008/10/23 12:19
red_johnny Re: pheasent huntin
Wow, thats a close one! Little bit higher and there might have been trouble.
Posted on: 2008/10/23 13:47
CentralCoaster Re: pheasent huntin
Naw had it been higher, pappy would have just ripped it in half with his teeth.
Posted on: 2008/10/23 16:37
MTVette Re: pheasent huntin
25 Posts
Wuz'e good eatin?
Posted on: 2008/10/24 2:28
When I first glanced at the pic I though pappy was packin' a 2x4 and swinging it at the pheasants.
Posted on: 2008/10/24 2:35
pr0zac Re: pheasent huntin
those are the dumbest birds. they walk/fly right out in front of you.
Posted on: 2008/10/24 21:52
Schrade Re: pheasent huntin
Rub-a-dub-dub... Fresh pheasant for the grub!
Least ya' ain't gotta' worry about bustin' yer choppers on #8 bird shot. Pheasant is VERY tasty uh huh!!!!
Posted on: 2008/11/9 17:59
