137 user(s) are online (107 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  SMC
Sheet Molded Compound.
This is the material that all C4 Corvettes are made of.
It's similar to fiberglass, but much more durable.
The onl...
denz93 Re: opti question
edwardsville il
48 Posts
it went on easy but hell it won't hurt to double check it just another hour of labor and a 12pack
Posted on: 2010/7/12 21:57
vis_croceus Re: opti question
VA
260 Posts
That's, uh, an hour of labor then a 12 pack, right?
Else we may have found root cause...
Have you got a way to scan the PCM? Would be helpful to see what the PCM thinks is going on.
The opti being off doesn't jive with
denz93 wrote:
the car runs good when cold
Posted on: 2010/7/13 7:17
94 vert
edwardsville il
48 Posts
no i have no way to scan the pcm what type of scanner is needed i might be able to get one
Posted on: 2010/7/15 20:26
tjpreul Re: opti question
Columbia, MO
1103 Posts
You can pull up the codes on the dash. I cannot remember which two to jump on the ALDL. My car has been acting funny with no codes (lights), and it had a MAP sensor code (34) stored.
Posted on: 2010/7/16 15:58
VA
260 Posts
You need a laptop, a cable and the free trial of Datamaster.
cable:
http://www.obd2allinone.com/sc/details.asp?item=aldlobd1u
(or similar)
[edit: changed link to <=93 cable]
datamaster:
http://www.ttspowersystems.com/DataMaster_downloads2.html
Posted on: 2010/7/16 20:22
94 vert
Columbia, MO
1103 Posts
cable:
http://www.obd2allinone.com/sc/details.asp?item=aldlobd2u
(or similar)
datamaster:
You can pull the codes from the dash. Put a jumper between pins A and G. Turn the ignition on, and it will go through its scan. If there are no codes you will get a C12 after the 1., and nothing after the 4. or 9.
http://www.corvettebuyers.com/c4vettes/ecm.htm
Posted on: 2010/7/17 1:12
BillH Re: opti question
The Stig Moderator
Reno
22702 Posts
tjpreul wrote:
cable:
(or similar)
datamaster:
Tyler, I agree he should check the codes but there's a big difference with the info on a datamaster scan. The datamaster shows the parameters on the engine.
Posted on: 2010/7/17 2:45
Every man dies but not every man lives.
Columbia, MO
1103 Posts
I was looking at the money. I know its not much, but if the car is running this bad there should be a code.
Posted on: 2010/7/17 12:25
VA
260 Posts
tjpreul wrote:
cable:
(or similar)
datamaster:
We heard you the first time.
He clearly already knows how to get codes, since he's posted them, and I clearly wasn't referring to pulling codes...
Posted on: 2010/7/17 14:00
94 vert
edwardsville il
48 Posts
Yeah there is no codes.
Posted on: 2010/7/19 19:02
VA
260 Posts
Anything new on this?
Posted on: 2010/8/2 3:28
94 vert
edwardsville il
48 Posts
putting the new msd opti on tonight
Posted on: 2010/8/2 18:50
edwardsville il
48 Posts
msd works like a champ. Lesson learned don't buy cheap opti's. thanks for all the advice.
Posted on: 2010/8/9 19:35
JAKE266 Re: opti question
Kempner, Texas
22 Posts
Guys post fairly often about a problem like this; other Forums are loaded with such exchanges.
Some continue to believe the Opti can ONLY go on ONE WAY, but you'd be surprised at just how many choose the WRONG location and install it wrong.
Right up until the time the guys realize they selected the wrong pin location that post that they're ABSOLUTELY SURE they installed in correctly.
Shoebox's, GrumpyVette's websites (and probably others) show exactly where the pin goes. I've got the photo saved if you need me to track it down and post it here.
In the meantime I suggest you go back over all your work before putting the problem off to a BAD new Opti. What I mean is EVERYTHING AND PAYING EXTREME ATTENTION TO DETAIL.
Hope this helps.
Jake
Posted on: 2010/8/13 21:18
__________________
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
The Stig Moderator
Reno
22702 Posts
Jake
So true Jake. The opti in this post is not pin drive though, it's spline drive. You can get it in wrong but you'd have to muscle it in using the bolts, yea some guys would try to. The splines will go in only one way with the opti sliding up against the block easily.
Posted on: 2010/8/14 2:13
