iCorvette | my 89 shakes very little compared to the 85 i had | ||
i can't believe how stable and stiff it is a ,very solid car, i had a lot of cars in between (20 years)
did chevy change the frame or just reinforced it? do those 2 frame rails run the length of the car?.. any pictures |
Posted on: 2009/9/9 15:24
BrianCunningham | Re: my 89 shakes very little compared to the 85 i had | ||
the Z51 cars got extra stiffeners, which became standard later on.
Of course I'm gathering the fully car car in your avatar is not yours. Though I approve of the driver |
Posted on: 2009/9/9 15:34
BeachBum | Re: my 89 shakes very little compared to the 85 i had | ||
For what its worth, my 85 is very tight.
Edit: Once I think about it, the rollbar probably helps that. I really don't remember what it was like before the rollbar. |
Posted on: 2009/9/10 0:33
863 cubic inches of C4 & C6 muscle C6 Corvette Z06 - Lemans Metallic Blue C4 Corvette 436 - Pure Black http://www.cardomain.com/ride/3933547 ... chevrolet-corvette/page-1 |
RedGut86 | Re: my 89 shakes very little compared to the 85 i had | ||
My 4pt roll bar made a very significant change in chassis stiffness. You could feel it but you could also see it when you went to jack up the front of the car and the rear came up too!
Posted on: 2009/9/10 6:23
My harness bar made a HUGE difference.
Can't wait to get a 6pt rollbar in it. |
Posted on: 2009/9/10 13:11
LesPutnam | Re: my 89 shakes very little compared to the 85 i had | ||
As Brian said, the 86 convertibles received considerable reinforcement (mostly internal the frame rails) and a bolt on X-brace. The Z51 and Z52 got the reinforcements starting in 87, but without the X-brace. The reinforcements MAY have become standard sometime later, but I've not confirmed that. Yes, the frame rails go the full length. Les |
Posted on: 2009/9/10 15:15
iCorvette | Re: my 89 shakes very little compared to the 85 i had | ||
then why is it i don't see them under the car?
that actually makes it better than mustangs with the unibodies cause the rails don't meet up in the center. really our cars sit on an old school frame |
Posted on: 2009/9/10 16:04
Under the car? They are not under the car. It is called a perimeter frame. When you sit in your C4 they are beside you, not below you. It's the reason why the sill is so high. It's not so "old school", the body is completely bonded to the frame. And it's the same construction as used for the C5 and C6. Les |
Posted on: 2009/9/10 17:39
