208 user(s) are online (73 user(s) are browsing Forums)
j3studio [1984-1987] How Hard To Adjust Emergency Brake?
After working for the five years I have owned my 1985, my emergency brake decided to stop functioning during a stunningly inopportune time (an NCRS Performance Verification).
How hard is it to adjust the emergency brake? Or is it possible that something worse has happened? It still makes the normal ratcheting sound...
Posted on: 2009/9/21 22:44
Matatk Re: {1984-1987] How Hard To Adjust Emergency Brake?
22959 Posts
Mine is self adjusting as far as I know for 88+, but here's a thread from CF:
http://forums.corvetteforum.com/c4-ge ... tment.html#post1560187929
Posted on: 2009/9/21 23:13
Vetron87 Re: {1984-1987] How Hard To Adjust Emergency Brake?
Granger, Indiana
1988 Posts
Do you have a factory service manual or Haynes? pull rear rotor and check for E=brakes out of adjustment/clean/lube cable unit with penetrating oil/keep lube off shoes. Put rotor on before testing EB.
Posted on: 2009/9/21 23:22
j3studio Re: {1984-1987] How Hard To Adjust Emergency Brake?
Thanks for the response and the hints. I do have the FSM - I'm just trying to get that all-important how hard is it advice...
Posted on: 2009/9/22 0:24
captmike13 Re: [1984-1987] How Hard To Adjust Emergency Brake?
Holden Mo
2181 Posts
Not to hard. I had to do mine last yr. I have an 85. The only hard part is getting the jack stands under it. And then reaching under to take up the slack in the equalizer.
Posted on: 2009/9/22 0:30
13 GMC 3500 dually
2015 VW Pissant
2003 Goldwing
I miss my Vette
captmike13@yahoo.com
Vetron87 Re: [1984-1987] How Hard To Adjust Emergency Brake?
Granger, Indiana
1988 Posts
Ditto
Posted on: 2009/9/22 0:54
j3studio Re: [1984-1987] How Hard To Adjust Emergency Brake?
Thanks, folks!
Posted on: 2009/9/22 1:41
CentralCoaster Re: [1984-1987] How Hard To Adjust Emergency Brake?
It's a 5 on a scale of 10. I remember it being tedious turning it a bazillion times with wrenches. Maybe clean the threads up with PB blaster first.
If it's totally gone, then pull the cover off of the door sill to the left of your seat. There's a pin in there and the E-clips tend to come off of it. This could let the pin release from the ratcheting mechanism. You should be able to see it at least without pulling the seat out.
Posted on: 2009/9/22 5:21
Hmmm...food for thought. Thanks, CC!
Posted on: 2009/9/23 2:13
