198 user(s) are online (143 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
klkordzi Started Her Up
Pittsburgh, Penna
152 Posts
I got the 85 started tonight and was able to break in the cam. I changed the heads for aluminum from an 86, port matched the heads and intake, added 1.6 roller rockers, headers and an adjustable fuel pressure regulator. I also eliminated the air pump and EGR and switched over to an 88's smaller starter. I had a lot of cleaning to do and had a couple false starts. First was the distributer being 180 degrees off cause I was watching the exhaust rocker rather than the intake when i was setting top dead center. Then I had a bad oil leak from the two piece Summit timing chain cover that forced me to drop the pan and take the entire front of the engine back apart so i could go back to the original cover. It was all worth it though after it fired right up and I ran at 2000rpm to break in the cam without a problem or leak.
Posted on: 2009/10/20 0:35
biggrizzly Re: Started Her Up
Good job! I bet it feels great to have that behind you.
Posted on: 2009/10/20 1:06
pianoguy Re: Started Her Up
Congrats!!
Posted on: 2009/10/20 1:07
bogus Re: Started Her Up
Way to go!!!
Posted on: 2009/10/20 1:36
Matatk Re: Started Her Up
Excellent! So how's it run?????
Posted on: 2009/10/20 2:46
klkordzi Re: Started Her Up
Pittsburgh, Penna
152 Posts
I need to check the timing and make sure everything like the idle etc are all where they should be. The idle has a nice lope to it and best of all, no codes.
Posted on: 2009/10/20 10:27
Mekanic Re: Started Her Up
Tampa Bay Florida
827 Posts
Good chit mang!!!
Posted on: 2009/10/20 11:00
~Rich
Polo LT4
BrianCunningham Re: Started Her Up
Must be a great feeling
Posted on: 2009/10/20 13:00
