flyboy | 113 heads valve lift question | ||
I have read on numerous other threads during a google search that .470 is the max. valve lift on stock 113 heads or there will be retainer/seal clearance issues. That the valve guides must be machined to go any higher. I spoke with the machinist at TPIS. He said he had a set of stock 113's with fel-pro seals and that he would run a check for me. He called back and said they were good to .525" lift. Does anyone out there have any knowledge on this? Thanks.
Posted on: 2009/11/1 23:57
sliding | Re: 113 heads valve lift question | ||
I know that when I installed #219 cam with stock 1.5 rockers I didn't have enough space. That combo is .525" lift. I was using positive style teflon seals. I have #113 heads dissasembled right now, so if you want I could measure from top of the guide to the bottom of the retainer. But you would have to add valve seals that you'll use to that equation
Posted on: 2009/11/2 14:19
'90 L98 auto with a lot of mods |
flyboy | Re: 113 heads valve lift question | ||
Thanks, I would appreciate that info. How did you rectify that problem, +.050" valve locks, pehaps?
Posted on: 2009/11/2 15:34
Matatk | Re: 113 heads valve lift question | ||
I know some guys have run the LT4 hotcam along with springs in the stock 113s. Here's an old thread from CF, check out post #10.
http://forums.corvetteforum.com/c4-te ... 113-casting-max-lift.html |
Posted on: 2009/11/2 20:29
Thanks, Mat. That's what I like about CF. Ask a question and you get nine opinions about something else before someone actually tries to answer the question.
Posted on: 2009/11/2 20:53
vetteoz | Re: 113 heads valve lift question | ||
Matatk wrote: LT4 / ZZ4 spring worked for me ; under $40 set http://paceperformance.com/index.asp? ... ion=VIEWPROD&ProdID=24732 $20 for the lightweight LT4 retainers http://paceperformance.com/index.asp? ... ion=VIEWPROD&ProdID=22758 Quote:
A little knowledge is a dangerous thing ![]() |
Posted on: 2009/11/2 21:48
Sorry, I didn't have time to measure, I'll get back to you with that info.
I solved my problem by machining (cutting the top) the valve guides. But when I installed my cam, I also added new double springs and retainers that are (if I remember right) thicker than stock retainers. I'll measure the spacing on the stock components for you tomorrow. |
Posted on: 2009/11/3 21:23
Thanks. The tech guy at Scoggin-Dickey Chev. also affirmed a .525 lift on the stock 113's. Hopefully these guys are more commited to giving accurate info. than just making sales.
Posted on: 2009/11/4 2:00
Here is what I measured at stock head. But I can't tell if this head (valves and seats) has been machined before what could give greater readings.
![]() I've also measured on one exhaust valve and reading was .671" Hope this helps you! ![]() |
Posted on: 2009/11/4 14:26
Thank you.
Posted on: 2009/11/4 23:57
