303 user(s) are online (262 user(s) are browsing Forums)
Driver Information Center.
turbotim23 Are there any better locker units for the dana 44HD rearends?
24 Posts
Hi I'm tring to rebuild a dana 44HD rearend this winter that I bought to replace the dana 36 in my 93 corvette. I was thinking of cyroing the stock posi housing but am wondering if I'd be better off just replacing it with a hiperformance one if there is a better one'. Thanks Tim
Posted on: 2009/12/7 21:26
vetteoz Re: Are there any better locker units for the dana 44HD rearends?
Posted on: 2009/12/7 22:39
CentralCoaster Re: Are there any better locker units for the dana 44HD rearends?
So it looks similar in operation to a Torsen type differential?
Looks like the best of both worlds of a locker and a differential.
Nice!
Posted on: 2009/12/8 0:01
BrianCunningham Re: Are there any better locker units for the dana 44HD rearends?
That's the one I want to run.
Looks like it's a little hard to get a hold of though.
Posted on: 2009/12/8 23:03
turbotim23 Re: Are there any better locker units for the dana 44HD rearends?
24 Posts
Summit can get them , said 800.30 Good Luck Tim
Posted on: 2009/12/10 17:44
