154 user(s) are online (124 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Collector Edition
RPO Z15.
1996 only.
LT1/A4 or LT4/ZF6....
ironcurtain What Happened? Throttle Cable Stuck?
39 Posts
I was hauling ass on the highway late on night and I basically just opened up my car. Just needed to get it out of my system but my foot was all the way down on the gas pedal at WOT and after reaching about 110mph i slowed down but I the gas pedal was stuck. When I woudl press it I felt pressure like there was air but it wouldnt give the car some gas. I dropped it back to OD and Drive again but still got stuck. After 10-15 seconds driving with the pedal stuck it finally let go...
what happened? And this has happened before and its always when im at WOT. Oh btw I have a 52mm TB if that helps...thanks :tongue:
Posted on: 2008/1/5 18:46
bogus RE:What Happened? Throttle Cable Stuck?
that has to be scary....
what year?
that makes a huge difference in things... I assume the cruise control wasn't turned on?
Posted on: 2008/1/5 18:50
RollaMo-LT4 RE:What Happened? Throttle Cable Stuck?
Trivia Winner
Rolla, Missouri
422 Posts
Sounds like you either have a cable hanging up, or the throttle blades binding. In any even, I'd want that fixed ASAP. That is a disaster waiting to happen.
Posted on: 2008/1/5 18:54
biggrizzly RE:What Happened? Throttle Cable Stuck?
Sounds like your floor mat got stuck on top the pedal!
Posted on: 2008/1/5 18:55
Trivia Winner
Rolla, Missouri
422 Posts
Oh yeah, don't rule out the easy fixes first. :toothy8:
Posted on: 2008/1/5 18:58
ironcurtain RE:What Happened? Throttle Cable Stuck?
39 Posts
How serious is it? and what could happen? its basically only when im at WOT..not really when im crusing. brakes works just fine.
Posted on: 2008/1/5 19:14
Klaus RE:What Happened? Throttle Cable Stuck?
Atlanta, GA
129 Posts
Sounds like you have a defective aftermarket TB.
Posted on: 2008/1/5 20:29
2008 Machine Silver Coupe
LS3 / Z51 / A6 / NPP
j3studio RE:What Happened? Throttle Cable Stuck?
Klaus,
Are you saying the TB could just stick wide open?
Posted on: 2008/1/6 19:08
runner140 RE:What Happened? Throttle Cable Stuck?
Ft. Lauderdale, Florida
721 Posts
Very serious....it could happen in traffic. Sounds like a cable problem. Get it fixed asap. :thumbleft:
Posted on: 2008/1/8 12:38
TommyT-Bone RE:What Happened? Throttle Cable Stuck?
33775 Posts
Accidently engaging the cruise control is a hoot. The car started accellerating leaving me saying WTF An application of the brake quickly resolved the issue. Quick reflexes and learned experiences have you going through the 1) Put it in neutral 2) Shut down the engine then you lose steering and braking power 3) Apply the emergency brake. It's amazing how I react under pressure. Sometimes I do the right things, sometimes I don't. You have to keep running senarios through your head and have quick reactions to avoid potentially hazardous situations. Like when someone cuts you off. If you have to think about it, it's already too late.
So, Did you isolate the problem?
Posted on: 2008/1/8 13:06
Atlanta, GA
129 Posts
Klaus,
I've read quite a few posts complaining about aftermarket TBs "sticking".
Posted on: 2008/1/8 13:14
I reask - WHAT YEAR?
If you have ASR (1992+), the ASR motor coulda fouled up, or the cable from the ASR...
Even the cruise control cable coulda fouled up...
Posted on: 2008/1/8 14:49
CentralCoaster RE:What Happened? Throttle Cable Stuck?
I don't really see how a TB can bind open at WOT. Ones I've seen tend to hang up when closing, that's when the bore/butterfly alignment is critical.
Posted on: 2008/1/8 21:48
dan0617 RE:What Happened? Throttle Cable Stuck?
[quote="TommyT-Bone"] You have to keep running senarios through your head and have quick reactions to avoid potentially hazardous situations. Like when someone cuts you off. If you have to think about it, it's already too late.
[quote]
I've had that problem. Someone cut me off and it took me too long to react.......by the time I got the gun up he was already too far away for a clean shot.
Posted on: 2008/1/8 22:33
