237 user(s) are online (170 user(s) are browsing Forums)
1Fast04Vert Going to pull the dogbones off
Supposed to be nice weather for a few days. So I am thinking aboout pulling the rear trailing arms off and rebushing them tomorrow.
Any words of advise before I hurt myself?
Posted on: 2010/1/19 3:43
Jeffvette Re: Going to pull the dogbones off
Have fun!
Posted on: 2010/1/19 3:44
Matatk Re: Going to pull the dogbones off
22812 Posts
Save the beer for after the job
Posted on: 2010/1/19 4:07
1Fast04Vert Re: Going to pull the dogbones off
One side done today, the other side will be tomorrow's project. It is really a straight forward job and I found an easy way to get the old bushings out. I simply used a vise, bolt with double nuts for length, and a large socket and pressed the metal sleeves out. Then cut thru the rubber bushing with a drywall saw and popped it right out.
Now it is time for that refreshment that Matt referred to.
Posted on: 2010/1/19 19:38
CentralCoaster Re: Going to pull the dogbones off
It's pouring buckets all week here. I'll have to put in some time in the garage. Until I fix what's in there, the vette won't fit.
Posted on: 2010/1/19 20:23
My only advice is make sure the suspension moves freely and the sleeves are being clamped down when you torque down the bolts, not the bushing face.
Posted on: 2010/1/19 20:24
Finished it today. At 220,187 miles the original bushings were a bit soft and I could see where they were moving a little, but no deterioration as far as any chunks of rubber missing or anything like that.
Guess the next project, whenever I got to it will be the front bushings.
Posted on: 2010/1/20 18:46
What bushings did you use?
Posted on: 2010/1/20 18:59
Hyper-flex by Energy Suspensions (polyurethane). Other than a few miles to settle the suspension I haven't driven it enough to give any meaningfull feedback. Back to the garage to retorque the wheel nuts and that job is done.
I put on the new radio bezel and shifter cover on Monday, so the only new parts still on the shelf are the SS brake lines.
Posted on: 2010/1/20 19:21
