Les94CompYellow | C6 rims on my C4?? | ||
[font=Comic Sans MS:f4ae8297c3] [/font:f4ae8297c3][size=12:f4ae8297c3] [/size:f4ae8297c3][color=black:f4ae8297c3] [/color:f4ae8297c3][align=left]
Hi Guys, I'm new to this forum, was a member of CF since 1996, sometimes things start to get old??? Heard about you guys from RollaMo-LT4....Thanks for that info. I need some help with this question, will "08 C6 stock rims fit on my C4? Will I need any type of adapter or spacer? What size rubber can I put on the back. I run 315's now on the rear and 275's on the front both 17" |
Posted on: 2008/1/9 5:23
CentralCoaster | RE:C6 rims on my C4?? | ||
Welcome!
Here's the short answer: The 8.5" fronts will tuck in about 1/2" more than stock 9.5s (or even with stock 8.5s if your car had those), The 10" rears will tuck in about 5/8" more than stock 9.5s. I would recommend a 3/4" thick adapter front and rear for a good stance. BUT, any adapter less than 1.125" thick will probably not work with reproduction wheels, since they don't clear the studs on the adapter. If you're using factory wheels you're fine. Here's the long answer that I added to the FAQ sticky. I don't know if you're running Grand Sport wheels in back with those 315s, but read below for the explanation. BTW, you can usually go about 3/4" past the factory "frontspacing" before you start sticking out of the fender. This will give you a more aggressive stance. Quote:
Posted on: 2008/1/9 6:52
RollaMo-LT4 | RE:C6 rims on my C4?? | ||
Trivia Winner
Les94CompYellow, glad to see you made it over.
I see CentralCoaster gave you a very detailed answer rather quickly. These guys know their C4's over here. |
Posted on: 2008/1/9 14:41
Les94CompYellow | RE:C6 rims on my C4?? | ||
Thanks for the welcome and for the rapid help. I guess all that is left now is to start spending money (as always). Now I have to decide on tire size and what will look best. The fun never ends. I;m looking forward to many more nites spent on this site. Thanks Again, Les
Posted on: 2008/1/10 3:54
PS: after being on the other site for over 12 years, it is strang to be called the "newby" again. It is like starting over.
Posted on: 2008/1/10 3:56
Rimcrew | RE:C6 rims on my C4?? | ||
Don't mean to hijack the thread, but are you going to keep the old wheels? I would be interesed in them if you want to sell.
Thanks. |
Posted on: 2008/1/10 4:59
red_johnny | RE:C6 rims on my C4?? | ||
I would love to do the same C6 rims on my C4
Posted on: 2008/1/10 12:07
I probably will put the rims and tires up for sale as soon as I get set up with the new stuff. The new rims certainly cant use the tires I have so they really should go as a package??? I will let you know as soon as I know about cost and how the new wheels look. If they look like crap the old stuff goes back on.(I really doubt they won't look great).
Les |
Posted on: 2008/1/11 1:54
Sounds great. Thanks
Posted on: 2008/1/11 3:04
