282 user(s) are online (227 user(s) are browsing Forums)
teebee, more...
smooth 94-95 cpu
Formerly "Aquavet" in Pa.
386 Posts
I forget if I asked you guys....I found a computer for a 94/95 LT1,(caprice so says the seller) will this at least get my new build running? Can it be sent to pcm for less for the proper programming later? its only $45
Alan
Posted on: 2010/5/28 14:09
Alan
2001 Navy Blue Metallic
bogus Re: 94-95 cpu
I guess the big question is if the harness is the same. I honestly don't know.
Logic would tell me it is similar, tho... same engine family... I assume the B-Body PCM was under the hood...
Posted on: 2010/5/28 14:32
BillH Re: 94-95 cpu
I'd get the part number and call these guys www.siaelec.com
They will rebuild a 94 for $95 and it looks like they have a 94 Corvette in stock for $170.
So for the Caprice + a rebuild, it's only $30 more to get the correct one.
Posted on: 2010/5/28 14:55
BrianCunningham Re: 94-95 cpu
The one in the Corvette runs the dash as well
I don't know if the Caprice can do that
Posted on: 2010/5/28 16:19
bogus Re: 94-95 cpu
no! The dash is run by the CCM, Brian.
Posted on: 2010/5/28 18:46
vis_croceus Re: 94-95 cpu
VA
260 Posts
Alan
If you're asking if you can run a Y body engine on B body code, I wouldn't. Very different tune in a B body.
Doubly so if you have any kind of mods, which I assume you must since you're talking about a mail order tune.
F code might be OK to run a stock engine on, although it will throw codes. I still wouldn't, though...
$45 is a reasonable price for the PCM itself. I've usually paid $50-60 shipped.
What's wrong with your current PCM?
Posted on: 2010/5/30 4:13
94 vert
