157 user(s) are online (125 user(s) are browsing Forums)
Very stout.
Weavsvet Heads are off......
446 Posts
Here are a few pictures. Looks like there was something going on in the #1 cyl. I hope it was in the valve train...........
http://s274.photobucket.com/albums/jj ... T/Head%20swap%20pics%202/
Posted on: 2010/5/31 13:13
pianoguy Re: Heads are off......
Ditto - hope someone who is good at reading piston tea leaves can chime in!
Posted on: 2010/5/31 14:41
PeteK Re: Heads are off......
I would buy a cheap small block chevy head gasket, retorque the drivers side, and leakdown #1.
That does not look good.
If you measure the valve and guide wear in that cylinder and it is good, I would be concerned.
Posted on: 2010/5/31 15:08
Weavsvet Re: Heads are off......
446 Posts
Thanks Pete,
What kind of tool do I need to measure the guide with? Will a digital caliper work that measures inside dimensions work? If it will what is the max it can be larger than the valve stem?
Posted on: 2010/5/31 15:18
Thanks Pete,
It would involve a machine shop. They have a special tool to mic the guides. Someone with a ton of experience can also move the valve off the seal slightly, and give it the "wiggle test" to feel the wear.
.0015 to .002 is typical valve guide clearance on a motor with some miles.
Posted on: 2010/5/31 15:24
I would not spend a whole lot of time diagnosing the guides. A leakdown test is probably best. If the rings are leaking excessively, better to know now, than later.
Posted on: 2010/5/31 15:45
446 Posts
Guess I was having a bad day when I did this.........dummy!!!!
Remember back when I had all those problems after the cam install? I had put a test spring on the number 1 cylinder to use with the degree kit. I had to change the base for the spring so I took off the oil seal. Guess what, I evidently forgot to put it back on and misplaced it and forgot about it. I would think that would let enough oil into the cylinder to smoke up the top of that piston like that. Hopefully this was a self inflected wound and nothing else is wrong.
I have no clue as to why you can't enlarge these pictures I put up here. I haven't moved or deleted anything. Sorry!
You can go here to see it in my album
[IMG]http://i274.photobucket.com/albums/jj256/WEVSVET/Head%20swap%20pics%202/IMG_3145.jpg[/IMG]
Posted on: 2010/5/31 16:01
That is a good sign. Normal age (and wear) combined with a compromised oil seal can definately result in what you have. Looks like your luck is improving!
Posted on: 2010/5/31 16:05
bogus Re: Heads are off......
20860 Posts
Yea... that #1 did look messy, but I'm with Pete, you dodged an expensive bullet!
Posted on: 2010/5/31 16:51
BrianCunningham Re: Heads are off......
nice progress
best of luck
Posted on: 2010/6/1 1:29
tpi421vett Re: Heads are off......
Salt Lake City Utah
125 Posts
Looking good
Posted on: 2010/6/2 4:19
08 C6 LS3,3LT,Z51,A6,NPP
450ci now with AFR 235...
