byebyeL98 | ZF6 slave cylinder - where to buy? | ||
I know for a while there had been a run of bad ZF6 slave cylinders from seemingly every source. Hopefully that is no longer the case.
Where should I go (dealership, online, etc) to buy a ZF6 slave? Thanks! Dan |
Posted on: 2008/1/13 14:04
´87 coupe, 383, ZF 6 Speed, 4.10s |
CasetheCorvetteman | RE:ZF6 slave cylinder - where to buy? | ||
Posted on: 2008/1/13 14:35
j3studio | RE:ZF6 slave cylinder - where to buy? | ||
Posted on: 2008/1/13 14:36
byebyeL98 | RE:ZF6 slave cylinder - where to buy? | ||
http://www.maxxwrench.com/ Thanks Case! Should I ask for Don? |
Posted on: 2008/1/13 15:28
Yes mate, he is a very good friend of mine. Tell him the whole story and see what he can do for you.
Posted on: 2008/1/13 15:55
Awesome, Case - thanks so much!
Dan |
Posted on: 2008/1/13 17:34
CentralCoaster | RE:ZF6 slave cylinder - where to buy? | ||
I thought there was a shortage for awhile where the warehouses were empty, and one of them was discontinued. Not sure if this was in response to the defective manufacture or not.
Either way I'd pull your new one apart and check and report back to us. If you need tips on flipping the seal, let me know. In fact I'll start another post on it for everyone to see. |
Posted on: 2008/1/14 2:36
Jeffvette | RE:ZF6 slave cylinder - where to buy? | ||
Just a FYI, the last half dozen I have gotten from GM, have been fine.
Posted on: 2008/1/14 2:48
I thought there was a shortage for awhile where the warehouses were empty, and one of them was discontinued. Not sure if this was in response to the defective manufacture or not. Thanks! I'll try to take some pics of my current slave for visual comparison to the new one. |
Posted on: 2008/1/14 18:10
Sorry - one more question:
What is the difference between the '89 - '90 slave cylinder vs the '91 - '96? Thanks! |
Posted on: 2008/1/14 18:26
Bleeder and hose attachment location.
Posted on: 2008/1/14 18:29
I searched for pics, but couldn't come up with any that showed the difference in locations . At MAM, they showed the same pic for both slaves .
Do you know what the differences are? IIRC, the slave I am currently using has a 12:00 inlet position and a 6:00 (or slightly offset) bleeder position (which I thought was dumb since air rises, but I use the Phoenix tool to bleed, so it didn't matter to me). Thanks! Dan |
Posted on: 2008/1/14 19:48
Doesn't matter the 89-90 slave is discontinued and the only option is the 91-96
Posted on: 2008/1/14 20:54
Thanks for the info. That explains why the pics on MAM are the same .
Posted on: 2008/1/14 21:19
MK 82 | RE:ZF6 slave cylinder - where to buy? | ||
Does anyone make a rebuild kit for these units? Last I heard, there wasn't one.
Posted on: 2008/1/15 3:01
96 CE Roadster LT4 |
Does anyone make a rebuild kit for these units? Last I heard, there wasn't one. I'll take the silence as a no. |
Posted on: 2008/1/18 14:35
Sorry mate, i dont think anyone saw the thread. I dont know personally.
Posted on: 2008/1/19 6:26
TorchRedRob | RE:ZF6 slave cylinder - where to buy? | ||
got mine from "thepartsladi" on ebay. Price was right, and it was properly assembled, though I strongly suggest pulling it apart anyway just to clean it- mine had lots of debris in it.
Posted on: 2008/1/21 2:53
LD85 | RE:ZF6 slave cylinder - where to buy? | ||
Posted on: 2008/1/21 13:26
2005/Z51 |
Parts America = Kragen/Schucks/Checkers AutoParts, fwiw.
Posted on: 2008/1/22 22:18
Does anyone make a rebuild kit for these units? Last I heard, there wasn't one. That's a shame. All you need is the seal and a wheel cylinder hone in most cases.. |
Posted on: 2008/1/23 0:36
Rex_Ruby | RE:ZF6 slave cylinder - where to buy? | ||
Quote: I was never able to locate a rebuild kit |
Posted on: 2008/1/23 4:59
