203 user(s) are online (72 user(s) are browsing Forums)
sliding Roller rockers not aligned ??
Zagreb, Croatia
326 Posts
I'll try to explain this as good as I can.
I've noticed that some of the rockers aren't sitting
on the center of the valve tip. If you take a look
at the pic below, you'll see that the RR on the right
isn't centered on the valve tip. It's positioned more
in the right direction (arrow) and roller tip is not
pushing on the whole valve tip but only on the right side
of the tip.
But I don't think that there's much that I can do.
I thought of grinding the holes on the guideplates to
make them adjustable a little bit. But if I do that, than
the other rocker on the same guideplate won't be centered.
Rockers are CompCams Pro Magnums, non self-aligning.
Any opinions?
Posted on: 2010/8/13 18:26
biggrizzly Re: Roller rockers not aligned ??
Things that make you go hmmmmmph!
I bought TrickFlow GuidePlates and they keep everything straight on mine. I have the same rockers as you. It also looks like it sits a bit forward of the valve stem too.
Can you post a photo of the guide plate?
Posted on: 2010/8/13 18:43
sliding Re: Roller rockers not aligned ??
Zagreb, Croatia
326 Posts
Sure, here is the pic. As for rockers beeing too forward,
you're right. I have to order new pushrods.
Posted on: 2010/8/13 19:10
CentralCoaster Re: Roller rockers not aligned ??
Who makes the guideplates? Looks like the forward slot isn't forward enough. Same way on the other cylinder.
Posted on: 2010/8/13 19:35
JAKE266 Re: Roller rockers not aligned ??
Kempner, Texas
22 Posts
ISKY sells adjustable guide plates.
Others have resorted to cutting and re-welding their plates.
DART sells slightly modded plates to address the slight re-positioning of their valves on their PRO1s. DART's site and literature say the slight off-set is NOT a problem. IIRC the offset distance is .030"
Hope this helps.
Jake
Posted on: 2010/8/13 20:05
__________________
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
vis_croceus Re: Roller rockers not aligned ??
VA
260 Posts
All SBC are like this to varying degrees.
Exactly how much varies with the particular head, rocker ratio, etc.
The only way to eliminate it completely is adjustable guideplates.
94 vert
Zagreb, Croatia
326 Posts
Thanks guys! I've ordered adjustable guideplates.
I have a big cam and springs and plan to rev it to 6500,
so it's better to be sure!
CC: the guideplates on pics are Competiton Cams product.
Posted on: 2010/8/14 11:34
When I had LLoyd Elliot do my head work, he suggested I not buy the CC guide plates and by the Trickflow instead. He gave no reason except that is what seemed to be working well with people that used his services.
Posted on: 2010/8/14 13:05
