zoe6 | Electrical ? | ||
Hi guys Have a quick electrical question. Voltage gauge in dash reads 13.6v. I took a VOM to check on board gauge accuracy still 13.6 volts. I'm under the impression that the alternator should be putting out 14.2-14.6v. I checked the battery, 13 month old Exide reads 12.8v. My question is since the engine and electicals seem "normal" is this a bad alternator issue! perhaps a blown diode? When I use the VOM as a shunt between positive cable and positive post of batt I read .06 v I would assume thats a normal parastic draw.
BTW body is 60% detared and began to wet sand hood with 2000 grit. Bought a quart of Victory Red and plan on blending blistered paint on rockers with an air brush. I appreciate you guys. Erin |
Posted on: 2010/8/19 21:46
bogus | Re: Electrical ? | ||
You could be looking at a dying alternator...
Considering the mileage, I would be more prone to blame weak brushes than a failing diode... diodes are queer, they die, you don't charge. I am sure you guys have a local rebuilder, I would take it him. I would say it is a full volt under what it should be. |
Posted on: 2010/8/19 21:50
Moved to C6 tech!
zoe6 | Re: Electrical ? | ||
Thank You Andy. Thats what I figured, alternator. I will remove the "little bugger" and tear it down! Thanks again
Posted on: 2010/8/19 21:58
Owner of a great Vette! Totally stock ZO6 |
1Fast04Vert | Re: Electrical ? | ||
Alternator output should be 13.8 to 14.2 and battery voltage should be 12.6 or better. Everything sounds good to me, including the parasitic draw.
Posted on: 2010/8/19 22:17
I checked the charging system at idle brights on, A/C on max, stereo on max(Brookes&Dunn never sounded so good)and left it that mode for 15 min. I would think that the alternator would be maxed out pumping those little electrons back into the battery. Maybe I will let it be for now and look up specs. Geez getting dads laptop pretty greasey. I checked the charging system on Dads 55Chevy (what a brute) at idle (1200) it reads 14.9 v. and returns to 13.7-14.2its a Powermaster 160Amp alternator. Those numbers seem more logical. Maybe 13.6V isn't that far off normal, its only .20-.06 volts. Thanks Erin |
Posted on: 2010/8/19 22:36
CentralCoaster | Re: Electrical ? | ||
13.6V is still plenty IMO, especially at idle. Does it increase at all as you rev it?
I would not consider replacing an alternator until it started dropping under 13V at hot idle with everything drawing. Anything over 12.8 is still charging. |
Posted on: 2010/8/19 22:39
CC I don't see any movement of the dash gauge but does move on the VOM it increases slightly. Another thought maybe the battery is so efficient in its recovery it does require that much charging voltage. Does that make sense? |
Posted on: 2010/8/19 22:44
BillH | Re: Electrical ? | ||
I agree with CC. A 13 month Exide is almost new, recovers faster. Just FYI, my 6 year old Exide reads 11.9 before startup and has been reading this for 3+ years. Alternator output with this old battery is 14.5 warmed up and sometimes 15.1. You can always pull the alternator and have it tested. If you're going to get into the electrical stuff on your C6, you should purchase a FSM (Factory Service Manual). They really help even for the C4's we drive. |
Posted on: 2010/8/19 23:56
I plan on a trip in two weeks with a considerable amount of night driving. I have the alternator out now and will take it our local Chevy Service Dept. for testing. I noticed today on my way to "the shop" how easy it is the break the tires loose with moderate acceleration. This is going take sometime to get use to especially in heels.
Posted on: 2010/8/20 0:11
In all seriousness, you may want to drive in something other than heels... just for better, more secure foot support. My wife always drove with flipflops, vs heels.
Posted on: 2010/8/21 4:28
I'm usually in scrubs and Nikes' but when I travel I have to look the part thus the heels. The ZO6 will require flats or better yet bare feet. Vetron has a 55 Chevy that should not be allowed on this planet that I tried to drive with nice shoes on, big mistake! Dad just smiled and replaced the garage door the next day. I noticed its difficult to removed yourself from a Corvette with a skirt on. I do drive with flip flops on I have noticed the ZO6 is not very forgiving if you somehow hit the gas instead of the brake. Dads Vette is an automatic. Erin
Posted on: 2010/8/21 20:39
