127 user(s) are online (89 user(s) are browsing Forums)
Steve40th Oil Temps with AC on, whats yours?
1114 Posts
While doing a long cruise around Oahu I noticed with AC on in stop and go traffic, my oil temps get to 230 real quick.
Now, I have BeCool radiator, and fan temps come on at 185/190 respectfully. With AC on I think they both come on.
Radiator is clean, nothing in front of it.
Temps were 90 degrees F out here.
Water temps were getting to 220 also.
This is pretty normal for my vette with 396, 2800 rpm stall and 3.75 gears. I run Mobil 1 5w 30.
Should I be concerned? My tune is set up to run leaner during cruising, as its set to 15.1 AFR vice 14.7.
Let me know what you think about the heat being incurred.
Posted on: 2010/9/13 20:37
Ko'u ohana aia ku'a ikaika
benny42 Re: Oil Temps with AC on, whats yours?
Houston, Tx
91 Posts
Sounds normal to me. Mine runs about 20* hotter than the water
temperature most of the time. Its about as hot here, but not
nearly as pretty.
Posted on: 2010/9/13 22:48
Vetron87 Re: Oil Temps with AC on, whats yours?
Granger, Indiana
1988 Posts
Last month with the humidty in the 90% range and temps near 98 with heat index of 105 my 87 oil temps hit 235 with the air on in traffic. I think thats the highest it ever been. Lowered to 210 once I was moving again. Your Ok.
Posted on: 2010/9/14 1:03
Bone stock 87 conv.
BillH Re: Oil Temps with AC on, whats yours?
I wouldn't be very concerned with Mobil 1 at that temp. I think my gauge reads low but I can see 225 in traffic.
Like Ron, I think you're OK.
BTW, I can get to 220 water in 5-6 longer red lights. And going up a mountain road behind cars, I hit 215 in about 2 minutes.
Posted on: 2010/9/14 2:41
Steve40th Re: Oil Temps with AC on, whats yours?
1114 Posts
Thanks guys, dont run AC much here in Hawaii, so it was kinda concerning.
Ya know, with the a/c on, your water temps should come down. Do your fan(s) come on when you hit a/c ?
Posted on: 2010/9/14 2:43
1114 Posts
Yes, they come on.
Posted on: 2010/9/14 2:45
Steve40th wrote:
Yes, they come on.
Good.
Just for compairson, I have 1 fan on a switch. In traffic at 217, if I turn that fab on, it will drop to 198 in 3-4 minutes.
Posted on: 2010/9/14 2:52
1114 Posts
I just have them turn on 185/ first fan and 190 second fan. Its hot under that hood, and being a bottom feeder car here in hawaii it is damn hot. I need to measure pavement temp with my laser temp sensor.
Posted on: 2010/9/14 3:01
