229 user(s) are online (169 user(s) are browsing Forums)
bogus [1987 parts] Free to Good Home
All sorts of parts:
1987 L98 fan shroud. I have 2 of these. One has been cut open to accept a pair of electric fans, the other is box stock.
1987 front HD fan.
1987 AIR pump. I cleaned this up. Looks pretty good. Flat rate shipment.
1987 A/C Compressor. I think this has a bad seal, but for flat rate shipping, its more than affordable. This is a flat rate shipment and thats all that fits in the box.
Posted on: 2010/4/24 20:56
george234 Re: [1987 parts] Free to Good Home
3 Posts
Do you still have parts or is this an old post?
thanks
george
I need an airpump hose and valve that goes from airpump to the cat. converter
Posted on: 2010/9/4 1:02
bogus Re: [1987 parts] Free to Good Home
I have the pump... but I question the need.
If you live in CA, then you will need it, but otherwise, it's a 10hp drag.
I only have the pump. The filter died a long time ago, as did the metal tubes that span the engine block.
Posted on: 2010/9/4 4:11
CentralCoaster Re: [1987 parts] Free to Good Home
thanks
george
Fwiw the air port on my cat is capped off, tube hasn't been on in years and no smog tech has called me on it yet.
Posted on: 2010/9/4 5:19
hell, you can't see the tubes... it's the pump that stands out.
Posted on: 2010/9/4 6:11
86PACER Re: [1987 parts] Free to Good Home
41 Posts
CentralCoaster wrote:
thanks
george
Same here. I've never had it. It was too much of a pain in the ass to install/remove so I left it out. I go to the same place every smog.
Posted on: 2010/9/27 7:57
cuisinartvette Re: [1987 parts] Free to Good Home
on the shroud that uses the single fan what is the opening size and width/lenth of the shroud?
Posted on: 2010/9/27 14:56
I will have to measure... It's stock 87 if that means anything.
I assume you want the diameter of the shroud and the depth?
I think I still have the fan.
Posted on: 2010/9/27 16:11
