bogus | [1987 parts] Free to Good Home | ||
All sorts of parts:
1987 L98 fan shroud. I have 2 of these. One has been cut open to accept a pair of electric fans, the other is box stock. 1987 front HD fan. 1987 AIR pump. I cleaned this up. Looks pretty good. Flat rate shipment. 1987 A/C Compressor. I think this has a bad seal, but for flat rate shipping, its more than affordable. This is a flat rate shipment and thats all that fits in the box. |
Posted on: 2010/4/24 20:56
george234 | Re: [1987 parts] Free to Good Home | ||
Do you still have parts or is this an old post?
thanks george I need an airpump hose and valve that goes from airpump to the cat. converter |
Posted on: 2010/9/4 1:02
bogus | Re: [1987 parts] Free to Good Home | ||
I have the pump... but I question the need.
If you live in CA, then you will need it, but otherwise, it's a 10hp drag. I only have the pump. The filter died a long time ago, as did the metal tubes that span the engine block. |
Posted on: 2010/9/4 4:11
CentralCoaster | Re: [1987 parts] Free to Good Home | ||
Fwiw the air port on my cat is capped off, tube hasn't been on in years and no smog tech has called me on it yet. |
Posted on: 2010/9/4 5:19
hell, you can't see the tubes... it's the pump that stands out.
Posted on: 2010/9/4 6:11
86PACER | Re: [1987 parts] Free to Good Home | ||
Same here. I've never had it. It was too much of a pain in the ass to install/remove so I left it out. I go to the same place every smog. |
Posted on: 2010/9/27 7:57
cuisinartvette | Re: [1987 parts] Free to Good Home | ||
on the shroud that uses the single fan what is the opening size and width/lenth of the shroud?
Posted on: 2010/9/27 14:56
I will have to measure... It's stock 87 if that means anything.
I assume you want the diameter of the shroud and the depth? I think I still have the fan. |
Posted on: 2010/9/27 16:11
