traiconghoa | Tail/fog light not working | ||
96 Vette. Suddenly my fog,tail, and dssh light stop working at s same time. Please help me to fix this problem? Thanks
Posted on: 2010/10/8 14:08
1Fast04Vert | Re: Tail/fog light not working | ||
I would bet they are all on the same fuse. Check panel on right side of dash.
Posted on: 2010/10/8 14:17
traiconghoa | Re: Tail/fog light not working | ||
CHeck the fuse....it look fine.
Posted on: 2010/10/8 15:14
Matatk | Re: Tail/fog light not working | ||
1) did you pull the fuse and visually inspect it? Did you check it with a DVOM? Sometimes they look good but are partially blown or you can't see it.
2) not to be insulting but did you check the right fuse? I have personally made that mistake so it's not a dig. The reason I ask is those lights are usually on the same circuit. Matthew |
Posted on: 2010/10/8 16:11
I just pulled the tail light fuse and virtually check it. Is there a fuse for fog light?
Posted on: 2010/10/8 18:29
ggrassmid | Re: Tail/fog light not working | ||
mine are on the same fuse with the accessory lights.
85 coupe |
Posted on: 2010/10/8 19:22
I'm not 100% sure on a 96...your owners manual will tell you if you have one. Otherwise someone with a later model will have to chime in. Matthew |
Posted on: 2010/10/9 12:44
