282 user(s) are online (245 user(s) are browsing Forums)
Tech Sport seat back removal
25 Posts
Hello
I am new to CG and a new 93 coupe owner. I Ebayed a set of factory sport seat inserts to help clean up the interior. The bottom cushion is easily popped out.
My question is how do I pop the top cushion off the back frame?
Tech
Posted on: 2010/11/5 14:02
pianoguy Re: Sport seat back removal
Posted on: 2010/11/5 14:18
BillH Re: Sport seat back removal
That article's ok.
I pulled mine and made a tool that makes it much easier.
More pics here:
http://www.corvette-guru.com/modules/ ... id=133283#forumpost133283
Posted on: 2010/11/5 15:46
CentralCoaster Re: Sport seat back removal
Push sides in very firmly, then they will unhook.
Getting them back in is harder than removing them.
The clips can be rusty though, which makes them harder to remove.
Posted on: 2010/11/5 16:58
Tech Re: Sport seat back removal
25 Posts
Thank you for the pics
That is just what I needed.
Could I use the string trick to put the top clips in??
Loop the string around the right wire
Tape the string ends to the left side so they don't get lost
Install the left wire into the seat clip
Pull on the strings
push in on the cushion to seat the right wire
Release one end of the string and pull it through
Tech
Posted on: 2010/11/5 19:04
93 Corvette
The first Chevy that I have ever owned
25 Posts
Using a string to pull the second wire over worked great.
I put the string on the inboard wire.
Seated the outboard wire in its retention clip
pulled on the string while pushing in on the head rest
You can feel the wire sliding across the clip.
It goes click and you release the pressure.
If I thought that the seat back was coming off any time soon I would have tried tucking the string in along the edge of the seat.
Tech
Posted on: 2010/11/8 15:08
