250 user(s) are online (91 user(s) are browsing Forums)
sliding New ignition system - yes or no?
Zagreb, Croatia
326 Posts
I'm thinking about upgrading my stock HEI.
I'm revving the new engine to 6500-6700 rpm and
I'm not sure how efficient stock HEI is at that rpsms.
What is your opinion on the subject?
Should I upgrade or not?
If yes, which system would you recommend?
Posted on: 2010/11/6 15:39
bogus Re: New ignition system - yes or no?
20861 Posts
If it was me, I would consider updating to an LSx style coil on plug. They are good to past 7000 RPM.
Another option would be to use a NASCAR style coil and distributor. They operate well into the 10k RPM range.
From my understanding of HEI, it will work up to about 7k, so you should be ok.
Posted on: 2010/11/6 21:55
Andrew Re: New ignition system - yes or no?
Jefferson City, MO
447 Posts
LS coils would be cool and very efficient! Do they make kits for this? Wouldn't you need a new computer? I bet it would be a lot of work.... I'd bet the Nascar style would be the easiest and cheapest way.
Posted on: 2010/11/6 23:59
2003 Atomic Orange Z06
SOLD 1979 4 Speed with 383
cuisinartvette Re: New ignition system - yes or no?
Upgarded module would get you there.
Dont have the info on coil on plug sure its out there. $$$
Posted on: 2010/11/7 0:39
20861 Posts
Sure is, www.eficonnection.com
Check it out.
Posted on: 2010/11/7 0:40
sliding Re: New ignition system - yes or no?
Zagreb, Croatia
326 Posts
I know that coil on plug is the best way to go, but
it's too much $$$ for my needs right now.
I think that I'll go with MSD 6al or similar setup.
Thanks!
Posted on: 2010/11/8 8:10
Tech Re: New ignition system - yes or no?
25 Posts
http://www.performancedistributors.com/index.html
These guys build great stuff. It drops in the hole and runs.
If it does fail, stock parts still fit so you can get home.
Tech
Posted on: 2010/11/8 15:25
Woodstock Re: New ignition system - yes or no?
Bremen/Germany
369 Posts
I read about MSD at 3rgd Gen forum and supposedly their distributors are fitted with Delco modules. Some guy called up at MSD and confirmed the story.
So my guess is, it's all in the coil. Get a good known coil and be down with it. That's what I would do.
Way too much advertising in the spark business, that has only proven to fill the mfg pockets.
Posted on: 2010/11/8 15:53
91 convertible
