sliding | New ignition system - yes or no? | ||
I'm thinking about upgrading my stock HEI.
I'm revving the new engine to 6500-6700 rpm and I'm not sure how efficient stock HEI is at that rpsms. What is your opinion on the subject? Should I upgrade or not? If yes, which system would you recommend? |
Posted on: 2010/11/6 15:39
'90 L98 auto with a lot of mods |
bogus | Re: New ignition system - yes or no? | ||
If it was me, I would consider updating to an LSx style coil on plug. They are good to past 7000 RPM.
Another option would be to use a NASCAR style coil and distributor. They operate well into the 10k RPM range. From my understanding of HEI, it will work up to about 7k, so you should be ok. |
Posted on: 2010/11/6 21:55
Andrew | Re: New ignition system - yes or no? | ||
LS coils would be cool and very efficient! Do they make kits for this? Wouldn't you need a new computer? I bet it would be a lot of work.... I'd bet the Nascar style would be the easiest and cheapest way.
Posted on: 2010/11/6 23:59
2003 Atomic Orange Z06 Sold - 1996 Competition Yellow LT4 - DRM 383, NX N2O, Line Lock, LT Headers, 3" stainless exhaust, Power Effects, and many more mods SOLD 1996 Competition Yellow LT4 SOLD 1979 4 Speed with 383 |
cuisinartvette | Re: New ignition system - yes or no? | ||
Upgarded module would get you there.
Dont have the info on coil on plug sure its out there. $$$ |
Posted on: 2010/11/7 0:39
Posted on: 2010/11/7 0:40
sliding | Re: New ignition system - yes or no? | ||
I know that coil on plug is the best way to go, but
it's too much $$$ for my needs right now. I think that I'll go with MSD 6al or similar setup. Thanks! |
Posted on: 2010/11/8 8:10
Tech | Re: New ignition system - yes or no? | ||
http://www.performancedistributors.com/index.html
These guys build great stuff. It drops in the hole and runs. If it does fail, stock parts still fit so you can get home. Tech |
Posted on: 2010/11/8 15:25
Woodstock | Re: New ignition system - yes or no? | ||
I read about MSD at 3rgd Gen forum and supposedly their distributors are fitted with Delco modules. Some guy called up at MSD and confirmed the story.
So my guess is, it's all in the coil. Get a good known coil and be down with it. That's what I would do. Way too much advertising in the spark business, that has only proven to fill the mfg pockets. |
Posted on: 2010/11/8 15:53
91 convertible |
