184 user(s) are online (133 user(s) are browsing Forums)
93Moneypit Used LT1 Short Block
Santa Cruz Ca
38 Posts
OK guys I'm thinking of picking up a used Lt1 94 corvette short block with 80.000 miles on it for a couple hundred to rebuild for my 93.
The guy selling it says it overheated when one of the heads cracked i don't have any experience rebuilding the Lt1 blocks do the Lt1 blocks have any problems with cracking like the standard 350 Ive Sean a few of those cracked.
Just wondering if i should steer clear of this engine thanks guys.
Posted on: 2010/10/20 9:57
rklessdriver Re: Used LT1 Short Block
The blocks do not usually crack but anything can happen.
Buy it only on the condition that it checks out good. Take it to a machinest and have it pressure tested (about $50.00).
Posted on: 2010/10/20 12:14
93Moneypit Re: Used LT1 Short Block
Santa Cruz Ca
38 Posts
Thanks rklessdriver I'm going to go take a look at it tomorrow or Friday take my straight edge and a strong flashlight and cross my fingers LOL.
Posted on: 2010/10/20 22:09
Santa Cruz Ca
38 Posts
Well guys the 4 bolt lt1 short block i picked up checks out ok.
It was a little rusty in one cylinder so i had to have it punched 30 over im having everything done Bord- balanced-pressure checked-magnaflux with a stock rebuild on the old crank and cam rods for $ 2 k I'm happy with that.
I'm going to have them do my heads what do you guys suggest for the valve springs and rockers my heads have no rockers so im thinking rollers
Posted on: 2010/11/9 10:55
bogus Re: Used LT1 Short Block
If your doing heads, rollers are a MUST. They are worth 2-tenths, seriously. The best bang for buck you can get on a SBC.
Posted on: 2010/11/9 17:03
JAKEJR Re: Used LT1 Short Block
KEMPNER, TEXAS
45 Posts
93Moneypit wrote:
Well guys the 4 bolt lt1 short block i picked up checks out ok.It was a little rusty in one cylinder so i had to have it punched 30 over im having everything done Bord- balanced-pressure checked-magnaflux with a stock rebuild on the old crank and cam rods for $ 2 k I'm happy with that.
Well, I'm glad to see your block checked out okay, mine didn't. Pressure test showed a leak where the previous shop did the grinding to clear the stroker crank.
Now I'm searching for a welding shop in the Dallas area . . . Anyone have a recommendation?
Jake
Posted on: 2010/11/22 3:35
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
96 Vette; 388 CID, all forged bottom end, ported AFRs, etc.
Santa Cruz Ca
38 Posts
Jake
Sorry to hear that your block leaked ill sell you my old block for cheap but the shipping will probably kill you from Calif to Texas.
Posted on: 2010/11/25 8:47
KEMPNER, TEXAS
45 Posts
Jake
Thanks for the offer but I bought one locally today and already dropped it off at Reher&Morrison.
Good luck with yours.
Jake
Posted on: 2010/12/3 0:01
